Scripts AEscripts for After Effects (x64)
Đồ họa & Thiết kế
Gửi bàigửi bởi anchang » 05 Tháng 3 2014, 09:59
165 scripts for After Effects can streamline functions such as camera setting to optimize workflows and automate tedious tasks it.
When we work in After Effects, then in the process we create projects, compositions, layers, masks, add effects, etc. In scripting each element is called an object. Each object has its own attributes and their values ??of the parameters that distinguish it from other objects.
The script will follow all instructions manipulating these objects: create, cancel, copy, animation, rendering, etc.. Other words, what we usually have to do with the mouse or keyboard, can be represented in the form of instructions in the script ( However, some actions are still available).
Scripting copes well with repeated procedures that tedious manually. That it might take many minutes or hours can sometimes be performed in a fraction of seconds with a few lines of the script.
It automates all the tasks, in addition, allows for some manipulation that without resorting to scripting, you create a project can not be implemented (for example, at the level of masks).
http://www.kingfiles.net/nwl42aojyj59/Scripts.AEscripts..rar
http://rapidgator.net/file/fd8e2112cc9b634e7b1a7fe7a614004a/Scripts.AEscripts..rar.html
http://uploadrocket.net/ijeczzpkl5oj/Scripts.AEscripts..rar.html
http://uploaded.net/file/61o9c75e/Scripts.AEscripts..rar
http://turbobit.net/wcg1pd4lv53z.html
