Diễn đàn THIÊN AN • Xem chủ đề - PassMark BurnInTest Pro 7.1 Build 1009 (x86x64)
Phần mềm ghi dĩa CD / VCD / DVD
Gửi bàigửi bởi anchang » 14 Tháng 8 2013, 14:33
PassMark BurnInTest™ is a software tool that allows all the major sub-systems of a computer to be simultaneously stress tested for endurance, reliability and stability. Anyone who has used computers for any period of time will understand the importance of having a stable system. The cost of a hardware failure can be enormous. If you are lucky your data will only become inaccessible while faulty components are replaced. If you're unlucky you can lose your files completely or have them permanently corrupted. Even if you have good backups, you can still lose days of work returning the PC to its pre-failure state. In many cases the lost data can never be replaced and businesses can be brought to their knees, with the loss of documentation, customer details and financial records.
The application includes the following additional features:
Online help & PDF manual
A customer style results certificate
Support for printing results
Logging of results to disk in user selectable levels of detail (in ASCII format & HTML formats)
Timed test runs that will stop automatically at the expiry of the selected time or after a number of test cycles.
The ability to save your results to disk as log file.
'Notes' and 'Machine ID' fields for storing your own audit information along with the saved log file.
Support for copying the results to other applications (eg. MS-Word) via a variety of image formats. (BMP, GIF, EMF)
The ability to select the level of load placed on each component, via the setting of a duty cycle for each test.
Counters that count the total number of operations performed.
An easy to use point and click interface
Can be run from a USB drive or CD (under Windows)
Summary system information including CPU type, CPU speed & Serial number.
Temperature monitoring interface (with additional 3rd party Intel Active Monitor, HMonitor, MotherBoardMonitor and SpeedFan software)
Laptop battery & UPS monitoring interface (with additional BatteryMon software)
Support for production line automation and detailed logging
RAM testing beyond the 4GB barrier in Windows 2000, XP and Vista (up to 64GB of RAM)
Printer testing using raw print files, or standard B&W or color testing
MP3, Midi and Wave file playback for sound card testing
Testing of up to 20 hard and floppy disks simultaneously
Testing of up to 20 CD/DVD drives simultaneously
CD / DVD testing using specialized test CD/DVDs (or use the complementary CD-Maker software). CD burner testing
Windows shutdown and cyclic reboot testing (with complementary Rebooter software)
Scrolling 'H's for Electromagnetic Compliance (EMC) testing to ANSI standard C63.4-1992
Video RAM testing
Testing the playback of Videos
Support for SMART hard disk parameter checking
http://rapidgator.net/file/f0d00557164667aaa35de6fd0922fbfd/BurnInTest_Pro_7.1_Build_1009.rar.html
http://turbobit.net/jkpzbly81hrz.html
http://sanshare.com/ldvbfv7byofb/BurnInTest_Pro_7.1_Build_1009.rar.html
http://akafile.com/d52ry8pzakhs
http://cloudzer.net/file/hss5ku6m/BurnInTest_Pro_7.1_Build_1009.rar
http://xedaiphattai.com http://xe-tre-em.xedaiphattai.com http://xetreem.xedaiphattai.com
anchang
Quay về Burning & RIP - Ghi dĩa - Ổ dĩa ảo - Các file ảnh dĩa
