UltraISO Premium Edition 9.3.6.2750 ML Retail | 3.75 Mb
Gửi bàigửi bởi Nửa bốn mùa » 23 Tháng 4 2011, 15:31
UltraISO Premium Edition 9.3.6.2750 ML Retail | 3.75 Mb -=FS=-
Duplicate Disc to CD/DVD Image
Build Files/Folders to One ISO File
Organize and Manage Efficiently
Edit and Convert ISO File in Many Format
Make Bootable CD/DVDs
Create/Edit Audio CD Image
Along with the large capacity hard disk popularity, people were already used to copying compact discs to CD/DVD image files, generally used is the famous ISO 9660 international standards format, therefore CD/DVD image files are called ISO files. Because the ISO file retained complete data information of the compact disc (including compact disc boot information), you were allowed the convenience to use commonly used CD/DVD burning software (for example Nero-Burning ROM ) to record the disc with your CD-R/RW or DVD-R/RW over and over forever, it can also be used directly through Virtual CD/DVD-ROM drive software (for example Daemon-Tools ) .
UltraISO is an ISO CD/DVD image file creating/editing/converting tool and a bootable CD/DVD maker , it can directly edit the CD/DVD image file and extract files and folders from it, as well as directly make ISO files from your CD/DVD-ROM or hard disk. At the same time, you can maintain the ISO bootable information, thus creating your own bootable CD/DVDs. You now have the power to make and edit your own ISO files, and then burn them to CD/DVD for your own needs.
UltraISO is in sole possession of the intellectualized ISO document format analyzer, it can process at the present time almost all types of image files, including ISO and BIN, it may even support new image files which are yet to be created. UltraISO can open these image files, directly extract files and folders, edit it and convert other image files to the standard ISO format.
UltraISO uses the double window unification user contact interface, you have the choice to only use the quick buttons and/or the mouse Drag & Drops, you can handle any CD/DVD image file easily.
Main Features
Can directly edit the ISO image file.
Can directly extract files and folders from ISO image file
Can add / delete /create new directory /rename ISO file image content.
Can make ISO file from hard disk document.
Can create CD/DVD image from CD/DVD-ROM, maintain bootable information.
Can process the compact disc boot information, you can directly add/remove/extract boot image of the ISO image.
Supports nearly all known CD/DVD image file formats (.ISO, .BIN, .IMG, .CIF, .NRG, .MDS, .CCD, .BWI, .ISZ, .DMG, .DAA, .UIF, .HFS and so on) , and can convert them to the industry standard and widely supported ISO image format.
May directly set the file/folder to hidden attribute
Supports ISO 9660 Level1/2/3 and Joliet extension
Automatically optimizes the ISO image file structure, saves the disc space.
Supports the shell document type integration, Open Image files through double clicking them or the Right Click menu of the mouse with the open dialog.
The double window user interface is extremely convenient to use.
There are rich add-on tools, you can create ALL in 1 bootable compact discs, CD/DVD image file management, even the virtual CD/DVD drive , those functions are really powerful.
System Requirement
Windows 7/2008/Vista/2003/XP (32bit and 64bit), Windows 2000, ME, 98SE, 98, or Windows NT4.0 SP6a+ operating system .
DOWNLOAD
http://www.fileserve.com/file/JPAb6tP/ESUPE9.3.6.2750.rar
Nửa bốn mùa
Đang xem chuyên mục này: Không có thành viên nào trực tuyến.11 khách.
