Coolutils Total PDF Converter 5.1.22
Gửi bàigửi bởi Giọt nước » 26 Tháng 10 2014, 21:42
Coolutils Total PDF Converter 5.1.22 | 30.75 MB
Total PDF Converter converts PDF files to HTML, DOC (Word), text, Excel, PostScript, CSV or image files (e.g. TIFF). When you need to convert PDF files to other formats or PS to PDF, Total PDF Converter is the ultimate choice. Why? Because, it's fast, easy-to-handle, accurate, doesn't require Adobe Acrobat, supports many target formats and has a batch option (can convert hundreds of PDF files as well as single files). In addition to this, registered users get command line support to manage the utility with maximum efficiency.
http://ul.to/x1ccmqb7
