Edit PDF as easy as on Microsoft Office Word
iSkysoft PDF Editor for Windows enables you to edit PDF document in a way similar to how you edit MS Word. All tools are easy to access, like adding
and deleting text, images and links. It also allows you to convert PDF files to Word, Excel, PowerPoint, Image and more.
Mark up and annotate Your PDF documents
Making annotation on the crucial content enables you to find the important content on a PDF document next time. iSkysoft PDF Editor includes highlight, underline, strikethrough, sticky note, text boxes, rectangles, and clouds tools etc.
Edit or convert scanned PDF (Requires OCR Plug-in)
Once the PDF OCR Plug-in is enabled, you can easily edit any scanned PDF files and convert scanned PDF documents to Microsoft Office Word, Excel, PowerPoint and more. Note that OCR plugin is an add-on to PDF Editor which can be purchased separately.
Encrypt PDF documents with password
iSkysoft PDF Editor enables you to secure your PDF documents with password to prevent from opening, editing, copying or printing. What’s more, this powerful editor has the ability to decrypt any password protected PDF document.
Merge and Split PDF files in only one click
Merging and splitting PDF document can be as easy as a breeze by using iSkysoft PDF Editor. You are able to drag and drop PDF files for editing at a time. The splitting function allows you to split a PDF file into many pages according to the number of pages you set.
Create PDF files from Word, Excel, etc.
Make PDF documents from existing files like Word, Excel or PowerPoint. iSkysoft PDF Editor has the ability for you to remove unwanted pages, rate pages, or insert new pages, images and graphics. Simply click to edit any added image or adjust the size.
http://turbobit.net/py00fpt8cun3.html
http://uploaded.net/file/958378sa/iSkysoft.PDF.Editor.3.0.0.2.rar
http://www.filefactory.com/file/2vtizxugej95/iSkysoft.PDF.Editor.3.0.0.2.rar
http://hugefiles.net/3npc9c7nyph0/iSkysoft.PDF.Editor.3.0.0.2.rar
http://rapidgator.net/file/7783312e6bfda7a3aff7f181f388375f/iSkysoft.PDF.Editor.3.0.0.2.rar.html
