SoftInterface Convert Doc 8.015 Multilingual
Gửi bàigửi bởi anchang » 14 Tháng 8 2013, 14:39
'Convert Doc' is a simple to use, yet sophisticated document conversion utility. If you need to convert/manipulate thousands of files with a variety of file types located within many folders in a short period of time, this is the tool.
'Convert Doc' can be especially useful if you require complicated file conversion jobs done on a regular basis. By saving and recalling a conversion job file, 'Convert Doc' quickly remembers all the file conversion tasks and their details. Also, 'Convert Doc' may be run from the command line allowing for use in batch files or can be launched from within other programs.
' Convert Doc ' Features
Supports fast conversion of PDF, DOC, DOCX, RTF, HTML, TXT and more... MS Word NOT required. Acrobat NOT required.
Choose between using our own fast conversion or MS Words conversion algorithm.
Excellent PDF Conversion support. Convert PDF to DOC (MS Word), PDF to RTF, PDF to TXT, PDF to HTML, DOC to PDF, RTF to PDF, HTML to PDF etc. PDF and PDF/A-1b supported. PDFs can be digitally signed (X.509).
Schedule unattended conversion jobs at regular intervals (time or calendar based).
Move or delete the input files after processing
Save and restore complex conversion configurations
Special processing of files including Concatenation (appending), removing extra lines, launching 3rd party programs, search and replace strings.
Supports recursive subfolders
Can be adapted for all languages
Batch can be stopped midway and resumed at a later time.
Automate from the command line or with the COM/ActiveX interface
http://rapidgator.net/file/272ede780211449b68cca4b42c8dcba9/SoftInterface_Convert_Doc_8.015.rar.html
http://speedshare.eu/m20g8scdgesc/SoftInterface_Convert_Doc_8.015.rar.html
http://akafile.com/wjjrhgm88w3i
http://sanshare.com/6z4i0bgtk934/SoftInterface_Convert_Doc_8.015.rar.html
http://cloudzer.net/file/fourmf17/SoftInterface_Convert_Doc_8.015.rar
