GiliSoft Video Editor v6.8.0
Phần mềm âm thanh và hình ảnh
Gửi bàigửi bởi anchang » 30 Tháng 1 2015, 21:36
No need to be worried about formats, frame rate or file sizes, the functions of video join, split and cut can be easily achieved by Gilisoft Video Editor. The video editing software allows you to edit video files in various formats like AVI, MPEG, H.264, SWF, MOV, WMV, etc. for playback on popular
devices like iPod, iPhone, PSP, PS3, and so on. The three processes, video join, split and cut, can run in background without too much space occupation.
As a video joiner, splitter and cutter, Gilisoft Video Editor has an intuitive interface and makes it easy to turn original videos into works of art. And also you can watch the video in the preview window. Gilisoft Video Editor is well worthy of having a try.
Features and Benefits:
•Format choice in joiner
You can join many videos in different formats at one time and the format of output file will be one of the input formats.
•Preferences in joiner
Gilisoft Video Editor allows you to set frame rate, bit rate, and resolution to get the best effect.
•Manual or auto split
Split manually by dragging the slider to locate the split point. Or split automatically by setting split time or file size, or averagely.
•Choose desired clips to output
Cut off any clips you want and they will be shown in list. If you are not satisfied with some clips, you can directly delete them in the list and output the desired clips as a one.
•Various parameters
The comprehensive video editing software provides many detailed parameters including frame rate, video bit rate, and resolution. By setting them, you will get expectant effects in a short time.
•Support preview
The video edit software supports previewing the source video and target file. If necessary, you can adjust the sequence of output video file.
•Run in background
You can run the video editing software in background when cutting, splitting or joining video to possess less space.
•Preview video
The video editor provides large preview window for you to preview the original and the output file.
•Hardware Compatible
Fully support Intel® Pentium D Dual-Core Processor and AMD Athlon™ 64X2 Dual-CoreProcessor;
http://uploaded.net/file/5661zfip/GiliSoft.Video.Editor.v6.8.0.WinAll.Incl.Keygen-DJiNN.rar
http://uploadrocket.net/k8eso7v6yc0q/GiliSoft.Video.Editor.v6.8.0.WinAll.Incl.Keygen-DJiNN.rar.html
http://rapidgator.net/file/c4365e33789991520e6b109cbb74aa02/GiliSoft.Video.Editor.v6.8.0.WinAll.Incl.Keygen-DJiNN.rar.html
http://www.filefactory.com/file/55dc822clfid/GiliSoft.Video.Editor.v6.8.0.WinAll.Incl.Keygen-DJiNN.rar
http://turbobit.net/p8pwv51l5lfa.html
http://xedaiphattai.com http://xe-tre-em.xedaiphattai.com http://xetreem.xedaiphattai.com
anchang
Quay về MultiMedia - Phần mềm Âm Thanh & Phim ảnh
Đang xem chuyên mục này: Không có thành viên nào trực tuyến.6 khách.
