Adobe Premiere Pro CC 7.1.0 Build 141 Multilingual
Phần mềm âm thanh và hình ảnh
Gửi bàigửi bởi anchang » 18 Tháng 11 2013, 21:59
Editing finesse
Edit more efficiently with a redesigned Timeline, intuitive track targeting, and dozens of new shortcuts. See critical information such as duplicate frames and through edits. With Paste Attributes, you can copy and paste the specific effects you need from one clip to another.
Link & Locate
Modern productions are built on hundreds (if not thousands) of clips. It's easy to lose track of files and backups saved on multiple drives. Link & Locate helps you track down your clips quickly, making media management — and your productions - more efficient.
Lumetri Deep Color Engine
Quickly apply rich, beautiful, preset color grades in Adobe Premiere Pro thanks to the Lumetri Deep Color Engine. With the Looks Browser, preview and add looks from Adobe SpeedGrade as easily as adding a dissolve. Also import LUTs from other systems.
Precise audio control
Control sound with the Audio Clip Mixer, adjusting clips independently for a perfect mix. Get hands-on with an audio control surface for more precision. Fine-tune with the TC Electronic Radar Loudness meter, and access effects plug-ins like VST3 and Audio Units (Mac OS only).
Adobe Anywhere integration
Adobe Premiere Pro integrates with Adobe Anywhere* for video. Team members work with files on a shared server without downloading. Avoid versioning problems. Make and review edits from any location. Assemble the best team — with no geographic limits.
s
Mezzanine codecs, native formats
Industry-standard mezzanine codecs are built in. Edit cross-platform with Apple ProRes (encode on Mac OS 10.8 only). Get cross-platform support for MXF-wrapped Avid DNxHD files. Natively edit even more formats thanks to new support for Sony XAVC and Panasonic AVC-Intra 200.
Closed captioning
Brand-new capabilities for importing and manipulating closed captions have been designed with editors in mind. Intuitively import, view, edit, adjust positioning and layout, and export media with closed captions — either embedded or as separate files.
Mercury Playback Engine
Now, more editors get real-time performance when working on complex sequences, thanks to support for a wider range of GPUs. Get enhanced, cross-platform support for OpenCL and CUDA. Render less often, work faster with third-party effects, and face deadlines with more confidence.
High-fidelity interchange
Get greater accuracy and a smoother workflow when importing or exporting Avid or Final Cut Pro projects. AAF import is more accurate, with improved support for DNxHD media. And, you can choose just the sequences you want when exporting to XML or AAF.
http://turbobit.net/ht9j2yq7rpvu.html
http://turbobit.net/7k7nf51vqya3.html
http://turbobit.net/c1bkyg78ip99.html
http://cloudzer.net/file/cp0eplrr/AdbPRmCC.7.1.0.141.part1.rar
http://cloudzer.net/file/gw8mlf88/AdbPRmCC.7.1.0.141.part2.rar
http://cloudzer.net/file/kwe6n0v9/AdbPRmCC.7.1.0.141.part3.rar
http://rapidgator.net/file/fffdfba84b0f11041bfa27456c88dcb3/AdbPRmCC.7.1.0.141.part1.rar.html
http://rapidgator.net/file/341149e05b924905df1a8982d55ce8a6/AdbPRmCC.7.1.0.141.part2.rar.html
http://rapidgator.net/file/0666126f8c7ad963849ec4eeb40beb3f/AdbPRmCC.7.1.0.141.part3.rar.html
http://sanshare.com/m71jx0jl1uv5/AdbPRmCC.7.1.0.141.part1.rar.html
http://sanshare.com/wa5fyteala5d/AdbPRmCC.7.1.0.141.part2.rar.html
http://sanshare.com/u0ereav99fxq/AdbPRmCC.7.1.0.141.part3.rar.html
http://uploaded.net/file/5f27m1dz/AdbPRmCC.7.1.0.141.part1.rar
http://uploaded.net/file/r4813v6w/AdbPRmCC.7.1.0.141.part2.rar
http://uploaded.net/file/b18tj8do/AdbPRmCC.7.1.0.141.part3.rar
Quay về MultiMedia - Phần mềm Âm Thanh & Phim ảnh
