LizardSystems Wi-Fi Scanner 2.0.0
Phần mềm hổ trợ INTERNET & Network
Gửi bàigửi bởi Giọt nước » 12 Tháng 7 2014, 16:01
LizardSystems Wi-Fi Scanner 2.0.0 | 2.12 MB
Wi-Fi Scanner is an easy-to-use tool to scan for and analyze 802.11 a/b/g/n wireless networks
Wi-Fi Scanner allows you to easily locate visible wireless networks and its corresponding information. The tool obtains the network name (SSID), signal level (RSSI), MAC address (BSSID), signal quality, channel, maximum data rate, encryption, and much more.
Wi-Fi Scanner is useful for normal access point users who need to find out the signal strength distribution for their wireless network at home, or choose a position for their access point for optimal signal quality.
Using Wi-Fi Scanner, you can evaluate the allocation of wireless networks by channel and select the least congested bandwidth for their access point, allowing them to increase their connection speed significantly.
In addition, Wi-Fi Scanner is an indispensable tool for corporate network administrators in performing tasks such as configuration, planning and monitoring security parameters on business wireless networks.
Key features :
- Simple, fast wireless network search.
- Connect to detected networks.
- Full support for both 802.11n and 802.11a/b/g.
- Display detailed wireless network parameters: network name (SSID), signal level (RSSI), MAC address (BSSID), signal quality, channel, maximum data rate, encryption, etc.
- Display changes in signal level over time in graphical form.
- Display signal spectrum mask for each wireless network.
- Change graph color for any wireless network.
- Filter list of detected wireless networks by specified parameters (quality, network mode, security, etc.).
- Display Wi-Fi radio state (software, hardware).
- Display wireless connection parameters.
- Display wireless connection statistics in the form of graphs and tables.
- Manage wireless connection profiles.
- Disconnect/connect wireless adapters.
- Different features available for different Editions.
Downlaod Links
https://www.oboom.com/CNXP1JAK
Quay về Internet & Network Tools
