Only with IP Video System Design Tool you can calculate both network bandwidth and storage space for 15 camera resolutions and several compression methods, including H.264, MPEG-4 and Motion JPEG. IP Video
System Design Tool helps the designer to find optimal FPS and compression that tailors to LAN capabilities and calculate the required HDD storage space. Frame size estimations are based on the result of our own compression research.
With IP Video System Design Tool you can:
Increase efficiency of your security system while lowering costs finding the best camera locations
Calculate precise camera lens focal length and viewing angles in seconds
Check the field of view of each camera and find dead zones to increase the security level of your premises using 2D and 3D modeling
Get estimations of required network bandwidth to shape the network video systems with any number of IP cameras and video servers
Calculate the required HDD storage space for video archive
Load site plan / floor plan JPEG or BMP background images from AutoCAD, Visio or Google Earth
Copy your calculations, drawings and 3D mockups to MS Word, Excel, Visio or other software to create an excellent project documentation
http://turbobit.net/5fn25yb42zcw.html
http://sanshare.com/pntegz09e86i/IP.Video.System.Design.Tool.7.0.Build.797.rar.html
http://cloudzer.net/file/j9684isx/IP.Video.System.Design.Tool.7.0.Build.797.rar
http://uploaded.net/file/g07538pv/IP.Video.System.Design.Tool.7.0.Build.797.rar
http://rapidgator.net/file/92ecc482ec1b57676b25710be5b7de4d/IP.Video.System.Design.Tool.7.0.Build.797.rar.html
