HyperSnap v8.04.02
Đồ họa & Thiết kế
HyperSnap v8.04.02
Gửi bàigửi bởi anchang » 30 Tháng 1 2015, 21:37
HyperSnap v8.04.02
HyperSnap is the fastest and easiest way to take screen captures from Windows screen and full screen games, and text capture (TextSnap™) from places where normal text copy is not possible. HyperSnap combines the power of a first-class screen capture application with an advanced image editing utility - wrapped into one easy-to-use tool!
It's perfect for capturing images that you want to include in your Help system, online tutorials, manuals, training handouts, presentations, marketing materials, Web pages, emails and more. Captures screens from full-screen games using DirectX/Direct3D technology. Use HyperSnap to quickly share a picture-perfect representation of anything on your screen.
HyperSnap is versatile and extremely easy-to-use. You can quickly customize menus and toolbars to fit your needs. Assign your own keyboard shortcuts, create instant toolbars, and even control HyperSnap with voice commands!
Here is a list of changes and new features in HyperSnap 8:
· 64-bit version, allowing the use of the full potential of modern 64-bit computers. Capture and edit much bigger images, fit in memory more captures simultaneously opened in HyperSnap window for editing and processing. A 32-bit version is also available for use on 32-bit systems.
· Thumbnails list - select all or several of captured images and right-click - Save Selected - Each image to its own file: now prompts you for the folder and image format to save in, instead of as in v.7 automatically saving to the last used folder and file.
· Thumbnails list - select all or several of captured images and right-click: added new function "Email selected", which will attach multiple images in selected file format to an empty email message.
· Wider lines when drawing shapes possible - under the "Line Style" tool, click "Wider Lines" menu item and type the new width in pixels.
· More "skins" under Setup ribbon tab - "Skin" button, including Office 2013 themes
· Other possible enhancements will be added to version 8, depending on your feedback.
http://rapidgator.net/file/4601e4189c680ce3c1b6300c66f0ad47/Hypersnap.rar.html
http://uploaded.net/file/g852lmgm/Hypersnap.rar
http://uploadrocket.net/5a8c73wv53r6/Hypersnap.rar.html
http://www.filefactory.com/file/2cw9jmmnqhlv/Hypersnap.rar
http://turbobit.net/kryjrpflqhxk.html
