HeliconSoft Helicon Filter 5.3.3.1
Đồ họa & Thiết kế
Gửi bàigửi bởi Giọt nước » 12 Tháng 7 2014, 16:25
Helicon Filter - a full-featured graphics editor c intuitive interface, fast previews, context-sensitive help at the bottom of the screen, which guarantee an easy handling of photos for beginners. The program is built as step by step workflow guiding you through all stages of processing images. Helicon Filter also has many advanced features of photo editing that will attract the attention of professional photographers.
Some of the most interesting and unique features are: Voice comments, filtering dust on the sensor, haze compensation, spectral sensitivity adjustment, chromatic aberration filter, vignetting and distortion correction; Stacking images to reduce noise and increase dynamic range when processing images.
Extras. Information:
* Create images with high dynamic range
* Multiprocessor support
* Batch processing for handling photos
* Support for external plugins
* Support for custom settings
* 16-bit precision processing photos
Helicon Filter is a complete photo editing solution for the digital photographer.
Its easy and intuitive interface, live preview feature, and contextual help ensure an easy start in photo editing for beginners.
The program is built as step by step workflow guiding you through all post processing stages of photo editing.
The video below shows how to improve an image in one minute (full screen mode, 720p recommended).
The most typical workflow is shown: crop and fix horizon, enhance brightness, set white balance, apply a bit of sharpening and add a nice frame.
Helicon Filter features:
File management:
* Voice comments and video playback
* Support for all popular file types including all RAW
* Fast folder browser
* Lossless rotate, copy, delete, move operations
* Template-based rename
* Full EXIF ??and IPTC information
* Support of color profiles
Noise reduction:
* Noise level auto detection
* Selective noise reduction in highlights and shadows, in defined hue, in color
range.
* Dead pixels filter (v.4.50 +)
* Dust sensor filter (v.4.50 +)
Brightness:
* Gradient haze compensation (v.4.50 +)
* Brightness equalizer / curve
* Brightness in Highlights, Shadows
* Contrast, Gamma, Exposure
* Local contrast
* Levels (black point, white point)
Colors:
* One-click White Balance tool
* Color map and RGB sliders for manual WB
* Memory colors list (several skin types, green, sky, etc.)
* Saturation for bright and dull colors
* Equalizer for selective saturation
* Spectral sensitivity controls
* Black & White conversion
* Exposure warnings
Aberration:
* Reduction of chromatic aberration on high contrast areas (eg sun behind the
tree)
Sharpening:
* Fine details extraction
* Edge sharpening
* Threshold to keep noise from sharpening
* White halo control
* Equalizer to sharpen only selected color ranges.
Distortions:
* Vignetting correction
* Barrel / pincushion correction
* Perspective correction
* Rotation, squeezing, stretching
* Skewing, bending
Crop / Resize:
* Presets for popular paper sizes, monitor resolutions, mobile phones
* Proportional selection (eg 2:3, 3:4, user defined)
* Batch crop / resize
Frames:
* Blurred or black & white image as a frame texture
* Color picker to choose frame color
Text:
* Placeholders for EXIF ??data (date, ISO, aperture, etc).
* Several text styles including embossed, shadowed, semi-transparent, inverted
text
Retouching:
* 'Delete scratches' brush to remove scratches, wires, pimples on the face,
etc.
* 'Clone' brush
* 'Change brightness' brush to make some areas darker or brighter
* 'Change color' brush to paint with color or to change the hue keeping the brightness the same
* 'Change saturation' brush
* 'Blur / sharpen' brush
* 'Reduce noise' brush
* 'Fix red eye' brush
* 'Distort' brush to fix protruding ears and similar problems
* 'Erase changes' brush to delete effect of the brushes and / or filters
* All brushes can be edge-sensitive
* Undo / redo is available
Save:
* Image can be saved to disk, emailed, printed
* Save dialog shows file size for give JPEG quality
* JPEG, JPEG2000, TIFF (24-bit, 48 bit, lzw compression), PNG, PSD, BMP formats
are supported
Advanced features:
* Creation of high dynamic range images
* Batch processing
* Support of external plug-ins
* User settings support
* 16 bit precision image processing
http://turbobit.net/cq9q2m0v57gx.html
http://rapidgator.net/file/8591f4d9b855dad58b68b034032f48ab/HeliconFilter.5.3.3.1.rar.html
http://fileom.com/rsif0v9za7pn/HeliconFilter.5.3.3.1.rar.html
http://uploaded.net/file/0peypa9t/HeliconFilter.5.3.3.1.rar
http://uploadrocket.net/z1do7ji59g9c/HeliconFilter.5.3.3.1.rar.html
