Paragon Hard Disk Manager 15 Professional 10.1.25.294 Recove
Gửi bàigửi bởi Giọt nước » 05 Tháng 11 2014, 14:22
Paragon Hard Disk Manager 15 Professional 10.1.25.294 Recovery Boot Medias (x86x64)
Paragon Hard Disk Manager - a multifunctional and convenient solution, has full maintenance cycle hard disk drive. With this program you can manage to boot, to make partition a disk, performed the operation up and recovery, to
ensure system and data security, disk output from service. The program is a convenient and practical tool for working with hard drives and data archiving for users of all skill levels. It is equally well can save data as a personal user and the enterprise.
System & data backup
Back up entire Windows system, individual partitions or selected files. Use the scripting engine to automate frequently used operations and benefit from the variety of virtual backup containers which simplify work with virtual environments. Whatever you choose – the space-saving pVHD format or a backup for later use as a virtual system (such as a virtual Hyper-V container), you will always have the full selection of backup options (sector and file-based, differential or incremental backups or special file complements). Password protection keeps sensitive data safe from unauthorized access. For data requiring special security, the Hard Disk Manager 15 Professional also supports drives encrypted with BitLocker.
Recovery & adaptation
With the Hard Disk Manager 15 Professional, you’ll always be on the safe side. Existing backups are no problem to restore thanks to integrated assistants – even on different hardware or in virtual environments (such as VMware Workstation, Oracle Virtual Box and MS Hyper-V). It gives you total flexibility and can restore the entire system, specific partitions or just individual files. The Universal Image Mounter (UIM) gives you full access to your secured files at all times. Simply map a backup archive as a network drive and the files it contains will already be accessible, just like they would be with a normal hard disk.
Paragon Recovery Medium
If your operating system won’t boot up anymore, you can fire up your PC with the bootable Paragon recovery environment and load in an existing backup, secure important data or rectify booting errors. The new Recovery Media Builder 3.0 makes it extremely easy and flexible to create your own personal recovery environment. And thanks to the latest WinPE technology, the recovery environment is also intuitive to operate. Are your backups on a network drive? Then use the advanced options and already add your network configuration and network drive while you’re still creating the recovery medium.
Partitioning & optimization
Advanced partitioning functions handle any hard disk partitioning task and help make optimal use of the available hard disk space. No matter whether you’re preparing a hard disk for use with multiple operating systems or redistributing storage space among several different partitions, you can always get top performance out of SSDs and hard disks with 4 K sectors and RAID volumes thanks to automatic partition alignment**.
Paragon ConnectVD allows you to work with virtual hard drives and is an indispensable function for anyone who uses virtual environments. ConnectVD makes it easy to manage virtual drives – for anything from partitioning or MFT defragmentation to data exchange. Advanced mode puts precise analysis and repair tools at your fingertips, allowing you to fix booting problems or analyze hard drive status.
Migration & virtualization
Migrate a Windows system from practically any source to any target – like from your old hard disk to a fast SSD. Convenient assistants guide you step-by-step to the result you want, but still allow plenty of settings options. Moving a Windows system to new hardware has never been easier!
The Paragon Hard Disk Manager 15 Professional virtualizes your running system or quickly and easily converts an existing backup into a virtual machine. Copy existing virtual machines with just a few clicks and adapt them for use with a different hypervisor (e.g. from VMware Workstation to MS Hyper-V). This even works with failed virtualizations which were conducted using software from other suppliers.
Dependable data wiping
Your private data is yours alone, even when you’re retiring an old hard drive. But data you’ve deleted can be restored by pros – even if the hard drive has been destroyed by mechanical means. With the Hard Disk Manager’s wiping function, however, you can free up storage space and make sure the data’s been deleted once and for all. All you have to do is use the military-grade wiping algorithms included (either individually or in combination) – or develop your own ones!
Hard Disk Manager Version 15 now gives you wiping functions for SSDs and erases SSD data safely without shortening the SSD’s service life!
BitLocker support
Many operations*** which the Hard Disk Manager 15 Professional offers can also be used on drives which were encoded with Microsoft’s encryption BitLocker technology. A big plus for everyone who manages sensitive data on their PCs!
What's new in version 15:
- (New) Agentless MS Hyper-V Backup
- (New) Secure data wiping – even on SSDs
- Free Update* for Windows 10 Support!
- (New) Agentless protection of Hyper-V guest machines
- (New) File-level backup/restore for virtual containers (pVHD, VHD, VHDX, VMDK)
- (New) Paragon Recovery Media Builder 3.0
- (Update) Refactored P2V Restore Wizard
- (New) Revised Graphical User Interface (GUI)
- (New) Wiping SSD
Paragon Hard Disk Manager 15 Professional 10.1.25.294 Recovery Boot Medias Windows 7 PE (x86/x64)
http://rapidgator.net/file/2b4c306350ed35aac1ac9f68a4d8da89/PHDM.Pro.10.1.25.294_000.RBM.w7PE.part1.rar.html
http://rapidgator.net/file/a6a89f6c9a589ea4d496eea21ceb06be/PHDM.Pro.10.1.25.294_000.RBM.w7PE.part2.rar.html
http://uploaded.net/file/stjj2coq/PHDM.Pro.10.1.25.294_000.RBM.w7PE.part1.rar
http://uploaded.net/file/z11xrdv8/PHDM.Pro.10.1.25.294_000.RBM.w7PE.part2.rar
http://uploadrocket.net/uneqxcd50wsn/PHDM.Pro.10.1.25.294_000.RBM.w7PE.part1.rar.html
http://uploadrocket.net/me19mtd9nddq/PHDM.Pro.10.1.25.294_000.RBM.w7PE.part2.rar.html
http://xerver.co/r5jonfrwbc0t/PHDM.Pro.10.1.25.294_000.RBM.w7PE.part1.rar
http://xerver.co/gt5v3gsicrtk/PHDM.Pro.10.1.25.294_000.RBM.w7PE.part2.rar
http://turbobit.net/s1hdaerlrdrq.html
http://turbobit.net/o421syqy8jh9.html
Paragon Hard Disk Manager 15 Professional 10.1.25.294 Recovery Boot Medias Windows 8.1 PE (x86/x64)
http://rapidgator.net/file/5dfe9443f0e8f813ff82ede5af9e2352/PHDM.Pro.10.1.25.294_000.RBM.w8.1.PE.part1.rar.html
http://rapidgator.net/file/9c497dfe56272736de220cfd46ba855b/PHDM.Pro.10.1.25.294_000.RBM.w8.1.PE.part2.rar.html
http://uploaded.net/file/q3v2sy11/PHDM.Pro.10.1.25.294_000.RBM.w8.1.PE.part1.rar
http://uploaded.net/file/jspfj8zj/PHDM.Pro.10.1.25.294_000.RBM.w8.1.PE.part2.rar
http://uploadrocket.net/nq3b0eznivbq/PHDM.Pro.10.1.25.294_000.RBM.w8.1.PE.part1.rar.html
http://uploadrocket.net/6yr1qpm9fibu/PHDM.Pro.10.1.25.294_000.RBM.w8.1.PE.part2.rar.html
http://turbobit.net/b5g1y1hcsyjk.html
http://turbobit.net/lo4fltttzex1.html
http://xerver.co/r3ajiy99w5nl/PHDM.Pro.10.1.25.294_000.RBM.w8.1.PE.part1.rar
http://xerver.co/2a6axvmv80ga/PHDM.Pro.10.1.25.294_000.RBM.w8.1.PE.part2.rar
