Total Commander PowerUser v63
Gửi bàigửi bởi anchang » 23 Tháng 8 2014, 12:40
Total Commander PowerUser v63 - a powerful tool for system administrators and advanced users, based on a modified version of Total Commander 8.01. The main criterion for the assembly - a maximum of functionality for every extra megabyte.
Unique in its kind assembly, where everything is left to chance. This is not a stupid stuffed with soft and carefully selected and repeatedly tested programs, utilities and plug-ins, also applies to the program settings, everything is set to the maximum functionality and comfort when working with Total Commander. All programs are grouped correctly in the toolbar, with the ability to select the desired category and easily move through them, as well as each program when the mouse pops up a brief description. The assembly is designed as a normal user, as well as for experienced / advanced users and system administrators. Arsenal programs is enormous, and can solve many problems! In this assembly has something for yourself and no one will be left untouched!
FAQ:
• A huge number of files (text, multimedia, graphics, etc.) to open F3, F4, alt + F3
• Many programs are in the drop-down menu of "Run"
• The Ctrl + PageDown you can go inside most of the packed files
• The icon "|", the one that the top-right, you can press Ctrl + drag
• If you want to update the assembly and load all the missing software, then run the TC PU - Update and download the program
http://rapidgator.net/file/97be7879e59766879002d87c0310c981/TCPU63.rar.html
http://uploadrocket.net/eucx24zem63r/TCPU63.rar.html
http://turbobit.net/l2e3t9476om4.html
http://xerver.co/3ysbirqg8ail/TCPU63.rar
http://uploaded.net/file/8v03w43q/TCPU63.rar
