Total Commander 8.51a PowerPack 2014.4 Final
Gửi bàigửi bởi anchang » 18 Tháng 5 2014, 10:09
Total Commander is a file manager replacement that offers multiple language support, search, file comparison, directory synchronization, quick view panel with bitmap display, ZIP, ARJ, LZH, RAR, UC2, TAR, GZ, CAB,
ACE archive handling plus plugins, built-in FTP client with FXP, HTTP proxy support, and more.
Key features:
- Updated user interface: flat buttons under Windows XP, new icons of files, records, buttons, discs, etc.
- Ability to set different colors for the background files and folders;
- Edit mode and manual synchronization when you compare files by content;
- A separate window with the folder tree for each of the panels - a new concept for Total Commander will especially enjoy the owners of widescreen monitors;
- The built-Lister appeared to display the cursor, centering the image and reduce the large images;
- Ability to change field values in the dialog content plugins attribute changes;
- Log file operations;
- Displays the drive letter in the tabs;
- Support for custom columns and thumbnails of pages for the system plug-ins;
- Instrument group rename files, you can edit the names of files directly;
- Added new option in the dialog when overwriting backup files: a comparison of files, renaming, automatic rename, copy all the files - the larger or smaller;
- Set the maximum length of command line;
- Sort multiple attributes (columns): Ctrl + Click on the additional column;
- AutoFill command line, current directory, copy dialog etc.
- Use a combination of Shift + Del to delete unnecessary items in the drop-down lists: command line, search, rename, etc.;
- Secure FTP-connection over SSL / TLS (requires additional OpenSSL-library);
- Customizable user commands to the main menu and hot keys;
- Alias commands (reduction) for the command line (for internal commands and external programs);
- Dialogue dubbing allows you to create previews and custom fields;
- Ability to file operations as a user with administrative rights (for access to private folders, you must enter the administrator password);
- Search on FTP-servers;
- Create ZIP-archives larger than 2GB.
http://rapidgator.net/file/95e21f36eb6fb3fc6b49a8a0a18f7d17/TC_8.51a_powerpack.2014.4.rar.html
http://uploadrocket.net/05mf0ijlus7d/TC_8.51a_powerpack.2014.4.rar.html
http://www.kingfiles.net/eq3clnqrc4fu/TC_8.51a_powerpack.2014.4.rar
http://turbobit.net/qepkm75ong4f.html
