TuneUp Utilities 2014 v14.0.1000.169
Gửi bàigửi bởi Giọt nước » 07 Tháng 11 2013, 23:49
TuneUp Utilities 2014 v14.0.1000.169 READ NFO-TE | 31 MB
MAKE SURE TO CLOSELY FOLLOW THE INSTALLATION INSTRUCTIONS AT THE BOTTOM OF THE NFO. FAILURE TO DO SO MAY RESULT IN FUTURE PROBLEMS! TuneUp Utilities 2014
Cleans and optimizes PCs like never before:
NEW! Flight Mode: Save more battery life and work on the go
NEW! Duplicate Finder: Delete unwanted duplicate files
IMPROVED! Disk Cleaner: Now cleans iTunes and 150+ programs
IMPROVED! User Interface: Now even easier to optimize your PC
New Features in TuneUp Utilities 2014:
TuneUp Utilities 2014 takes PC optimization to the next level to keep your Windows PC, laptop, and tablet in top shape. New features in version 2014 include:
Duplicate Finder - NEW!
Flight Mode - NEW!
User Interface - IMPROVED!
Disk Cleaner - IMPROVED!
Automatic Cleaning Updates - IMPROVED!
Boost your PCs Performance:
TuneUp Utilities 2014 includes advanced performance optimizers helping you achieve lightning-fast application load times, work faster and make your games run smoother
Program Deactivator
Startup Manager
Live Optimization
Drive Defrag
Turbo Mode
StartUp Optimizer
Performance Optimizer
Optimization status
Rating Function for Programs
Clean up your PC:
Now it s easier than ever to get a clean PC. TuneUp Utilities 2014 can quickly remove Windows , program and browser clutter while refreshing your registry and deleting massive disk space hogs
Browser Cleaner
Disk Space Explorer
Uninstall Manager
Shortcut Cleaner
Shredder
Registry Cleaner & Registry Defrag
Analyze & Fix Up:
Tired of calling up PC experts or costly tech hotlines? Then help yourself with TuneUp Utilities 2014. Its easy-to-use wizards and diagnostic tools help you find vulnerabilities and errors on your computer
Disk Doctor
Repair Wizard
Undelete
Process Manager
Status & Recommendations
System Information
Power Up:
We ve all been there. You re just getting to the end of that all-important document or exciting movie and your battery dies Now you can stop your battery wasting power on things you don t need so it can last longer
Flight Mode - NEW!
Economy Mode
Works Automatically:
We continually monitor your PC to help you clean and optimize And we even run our routine maintenance when you re away from your PC so it doesn t get in the way
Automatic Cleaning Updates - IMPROVED! 1-Click-Maintenance & Automatic Maintenance
Tweak & Style Up:
Bored with the same Windows themes, logon screens or icons? Ready to give your PC a makeover? TuneUp Utilities 2014 offers unique customization possibilities that ll transform the same old and boring Windows XP Luna and Windows 7 Aero design to something new, sleek, and exciting. And once you re done with that, TuneUp System Control helps you adjust more than 400 hidden Windows and program settings
Styler
System Control
Optimization Report
Settings Center
Overview of all functions
Fully compatible:
Windows XP
Windows Vista
Windows 7
Full Support for Windows 8:
Get ready for the future of Windows with the all-new TuneUp
Utilities 2013
Fully optimized for Windows 8
Prevents the gradual slowdown that plagues even the new
Windows 8
Keeps your PC clean from day 1
For More Info Visit:
http://www.tune-up.com/
IMPORTANT NOTICE:
As of 09/14/2013 ALL TE RAR archives will now be using the RAR5 standard. Please make sure to update to the latest version of Winrar (at least Winrar v5.0) so you can extract the contents of the *.001, *.002 etc... archives within the zip files. The update is free, there is no reason not to update
TE Release Filename: ttu1402x.zip
INSTALLATION NOTES
Install TuneUpUtilities2014_en-US.exe, which ONLY installs build 145. Make sure to UNCHECK: "Launch TuneUp Utilities 2014 when finished" on the final installation window
You can now either let the Update Wizard download and install the Build 169, or if your offline or prefer to close it, then unzip package_14.0.1000.145_to_14.0.1000.169.zip to a temp folder and then ONLY launch base_14.0.1000.88_to_14.0.1000.110.msp and allow this to update your TuneUp to v14.0.1000.169. AGAIN make sure to UNCHECK: "Launch TuneUp Utilities 2014 when finished" on the final update installation window
If you chose to manually update and recieved an error about file(s) inuse (because you didn't uncheck as stated before), make sure to close the front end and then stop the service "TuneUp.UtilitiesSvc" with task manager or launch services.mscand stop it there and then retry update
Finally make sure that TuneUp Utilities 2014 front ent isn't running, else shut it down, and copy over the precracked dll from the Crack folder, to the installed folder of TuneUp Utilities 2014. Make sure to allow the file to be overwritten. Now just import the Registration.reg into your registry by double clicking the file
You now have a fully registered version of TuneUp Utilities 2014! Appologies for this lengthy process, ever since AVG bought the rights to this software, they are continually being lazy asses and not updating the main setup download
OPTIONAL:
You can skip importing the registration file and use any info for registration. Its recommended to use the Registration file, as this has account registration step completed for you and also removes some previous blacklisting
Faster And Resume Supported Download Link
http://anysend.com/AA35D68AC3CB69ED9F4E63D8D0E70382
OR
http://ul.to/9n4uq8zp
