TuneUp Utilities 2014 14.0.1000.145
Gửi bàigửi bởi Giọt nước » 18 Tháng 10 2013, 09:17
TuneUp Utilities 2014 14.0.1000.145 | 58 MB
TuneUp Utilities 2014 can make your Windows operating system more comfortable, faster and more secure with just a few mouse clicks. And all operations performed on the operating system are completely safe, because all changes are monitored by TuneUp Rescue Center and can be undone at any time. All TuneUp Utilities 2014 modules can be accessed through a common interface that is divided into six categories. The software helps both beginners and experts to make Windows meet their needs in a way that is better, easier and safer. All important system options are explained in an easy way and can be turned on or off at the click of your mouse. TuneUp Utilities 2014 will then make the necessary changes in the registry or boot files automatically. The most changes that you make can be undone in TuneUp Rescue Center ? easily and safely.
The TuneUp Utilities 2014 Turbo Mode provides an immediate performance boost whenever you need it. When you use your computer in the TuneUp Turbo Mode, an analysis is performed to see which tasks, programs and functions are currently running in the background that are not strictly necessary. These programs are stopped or slowed down, allowing the additional processing power gained to be used exclusively by the programs you are actually running.
Maintain System
? 1-Click Maintenance and Automatic Maintenance
? Optimize system startup and shutdown
? Defragment hard disks
? Remove broken shortcuts
? Defragment registry
? Clean registry
Increase performance
? Turbo Mode
? Configure Live Optimization
? Free up disk space
? Configure system startup
? Display and uninstall programs
Home Page -
http://www.tune-up.com
Resume Supported Download Links
http://ul.to/ai4h3k9p
OR
http://www.tusfiles.net/m2hb7cmkokg6
OR
http://filesflash.com/xwwjsbgo
