Boot CD/USB Sergei Strelec 2013 version 4.0 (x86,x64)
Gửi bàigửi bởi Giọt nước » 22 Tháng 9 2013, 18:42
The boot disk Windows 8 PE - for working with disks and partitions, and restore the backed up disks and partitions , disk diagnostics . Also, there is a set of programs for data recovery and AntiSMS.
Programs :
Backup and restore
Acronis True Image Home 2013 16 Build 6514 PlusPack (Rus)
Active Disk Image Professional 5.5.2 (Rus- my translation )
R-Drive Image 4.7 build 4737 (Rus)
Ghost 11.5.1.2266 (Eng)
Paragon Hard Disk Manager 12 Professional 10.1.19.16240 (Rus)
Terabyte Image for Windows 2.83 (Rus)
AOMEI Backupper 1.6 ( Russian version WYLEK)
HDD
Disk Management System
Acronis Disk Director Home 11.0.2343 Update 2 (Rus)
Acronis Recovery Expert (Rus)
Paragon Alignment Tool 4.0
MiniTool Partition Wizard Professional 8.1 ( Russian version WYLEK)
EASEUS Partition Master 9.2.1 Server ( Russian version WYLEK)
AOMEI Partition Assistant Professional 5.2 (Rus)
AOMEI NTFS to FAT32 Converter Pro Edition 2.0 (Eng)
AOMEI Dynamic Disk Converter 3.5 Professional (Eng)
Active KillDisk Professional 7.5.1.1 (Eng)
Defraggler 2.15.742 (Rus)
HDD Low Level Format Tool 4.30 (Rus)
HD Tune Pro 5.50 (Rus Loginvovchyk)
Check Disk GUI
Victoria 4.47
HDD Regenerator 2011
other programs
AIDA64 Extreme Edition 3.20.2600 (Rus)
BlueScreenView 1.47 (Rus)
Active Password Changer Professional 5.0 (Eng)
Reset Windows Password 1.2.1.195 (Rus)
UltraISO Premium 9.5.3.2901 (Rus)
Small CD-Writer 1.4
Total Commander 8 (Rus)
Directory Opus 10.5.2 (Rus)
Registry Editor ( h86/64 ) (Rus)
Registry LoaderPE 1.0.19
Autoruns (Rus)
FastStone Capture 7.1 (Rus)
STDU Viewer 1.6.191 (Rus)
BOOTICE v1.0.6 (Eng)
Recovery master boot Windows (Rus)
Unlocker 1.9.2
7 -ZIP (Rus)
WinNTSetup 2.3.6.0 (Rus)
Installing the drivers manual and automatic
Check Device 1.0.1.38 (Rus)
Double Driver 4.1.0 (Rus)
Set the screen resolution
Imagex
Gmagex (Rus)
Opera 11 (Rus)
EasyBCD 2.2 (Rus)
Data Recovery:
R-Studio 6.3 build 154025 Network Edition (Rus)
O O DiskRecovery 8.0 Build 345 Tech Edition (Rus)
MiniTool Power Data Recovery 6.6 ( Russian version WYLEK)
Active Partition Recovery Enterprise 9.0.4 (Eng)
Active File Recovery Pro 11.0.5 (Eng)
Runtime GetDataBack for NTFS 4.33 (Rus)
Runtime GetDataBack for FAT 4.33 (Rus)
Antivirus
AntiSMS 4.1 (Rus)
DOS programs :
MHDD 4.6
Victoria 3.52
Memtest 4.20
changes:
updated :
Video driver (nat27 ru-board - September)
WLAN driver of county9
added:
Other minor changes.
Adding to multi-boot flash:
If you added a multiboot USB flash drive directly to an ISO image, you must extract STRELECPE folder in the root of the stick.
With an ISO image of all of the above , in this case can be removed if desired.
network:
Supported ways to connect with protocol TCP / IP, NetBIOS over TCP / IP and WLAN (Wi-Fi).
IDSL modems usually picked up machine .
To use Wi-Fi you need to install the wireless network adapter driver . Setting the Start Menu Drivers section .
Connecting to a Wi-Fi network through a program of PE Network, tab Wi-Fi.
Main features:
The contents of the disc is loaded into memory , after loading , you can remove the disc or USB flash drive from the drive.
To record a program on a flash drive using UltraISO (is in the archive)
Maybe install the driver from the Start menu on the video card . Install if you can not get acceptable for screen resolution. In
most cases this is not necessary.
For additional drivers using a program Check Device Dmitry Malgina . In its search capabilities and installation unwrapped
suitable drivers in any folder you specified . You can complete your packages if necessary drivers. This program is for
disk to install the drivers manually.
System requirements :
RAM ( random access memory ) of 1 gig .
A computer with the ability to boot from CD or USB.
Format : ISO
On the file:
Enabling | reg code : not required
Language : English and Russian
File format : rar
Platform / OS : x86/x64
DOWNLOAD LINKS:
http://rapidgator.net/file/5b135639865dfa82a7a5b45bf874bf39/Boot.USB.Sergei.Strelec.2013v.4.0.part1.rar.html
http://rapidgator.net/file/7dd4cb63c706950e370998b0e958bd88/Boot.USB.Sergei.Strelec.2013v.4.0.part2.rar.html
http://rapidgator.net/file/e8051cd7cae7e1afc3b6c04eaca66141/Boot.USB.Sergei.Strelec.2013v.4.0.part3.rar.html
