Acronis Backup & Recovery Server 10.0.13544 + BootCD | 424 M
Gửi bàigửi bởi Giọt nước » 19 Tháng 4 2011, 22:26
Acronis Backup & Recovery Server 10.0.13544 + BootCD | 424 Mb -=FS=-
Acronis® Backup & Recovery™ 10 Server for Windows is the next generation disaster recovery product, succeeding Acronis True Image Echo, designed to back up and protect stand-alone Windows Servers.
With Acronis Backup & Recovery 10 Server for Windows , the operating system, applications and data can be recovered in minutes, instead of hours or days.
Based on Acronis' patented disk imaging and bare-metal restore technologies, this comprehensive, yet simple-to-use product can help organizations minimize downtime to meet strict Recovery Time Objectives (RTOs), and cut costs.
Acronis Backup & Recovery 10 Server for Windows simplifies and automates the recovery process, even when you need to recover to dissimilar hardware platforms. With optional Acronis® Backup & Recovery™ 10 Universal Restore™ software, administrators can quickly recover a server to dissimilar hardware or a virtual machine to maximize recovery flexibility while minimizing business disruption.
If you already use Acronis Backup & Recovery 10 software for local backup and recovery of your physical and virtual machines, adding Acronis® Backup & Recovery™ 10 Online is a snap because the two products are completely integrated. One console seamlessly manages all of your backup and recovery efforts regardless of the data's actual location.
What happens when a system’s hardware fails or needs to be retired? How do you move the valuable applications and data to a new system or hardware after disaster strikes? How do you quickly restore a system after the hardware has changed?
Acronis solves this common issue with Acronis® Backup & Recovery™ 10 Universal Restore™, a fully integrated module that restores servers or workstations to different hardware or to a virtual machine, providing highly flexible disaster recovery and migration options.
The Acronis Backup & Recovery 10 Universal Restore module prepares you for even the most unforeseen events without requiring administrators to purchase and maintain identical spare machines.
The process begins when Acronis Backup & Recovery 10 is used to create a transportable image that disassociates the data from the old machine’s underlying hardware. Acronis Backup & Recovery 10 Universal Restore loads in the new hardware’s own drivers so that the image from the previous hardware platform will allow the machine to be flawlessly restored to a different hardware platform, complete with operating system, applications, data and all previous settings. Recovery can be implemented to an existing system, to a new system with different hardware, or to a virtual server, in minutes, by following these steps:
* Boot your replacement system with Acronis Backup & Recovery 10 bootable media you have created and select ‘Recovery’ in the menu.
* Select the image to restore.
* Acronis Universal Restore then initiates the restore process, detects the hardware and installs the appropriate drivers for Hardware Abstraction Layer (HAL).
* The result is a perfectly functioning system on a new hardware platform
Universal Restore™ requires Acronis® Backup and Recovery™ 10 to be installed.
Top Features:
* Recover — Recover a failed system to different hardware or a virtual server in minutes after unforeseen events.
* Clone and deploy — Clone and deploy operating systems with complete hardware independence
* Migratev — Complete physical-virtual, virtual-physical, physical-physical, or virtual-virtual migrations for system recovery, testing, and other purposes.
Supported operating systems:
* Windows 2000 Server SP 4+
* Windows 2003 Server SP 2+ x32 and x64 Editions
* Windows 2008 Server SP2 x32 and x64 Editions*
* Windows 2008 Server Foundation
* Windows 2008 Server R2
Supported file systems
Acronis Backup & Recovery 10 can back up and recover the following file systems with the following limitations:
* FAT16/32
* NTFS
Supported storage:
* Hard disk drives
* Networked storage devices
* CD-R(W)
* DVD-RW, DVD+R(W)
* ZIP®, Rev® and other removable media
* P-ATA (IDE), S-ATA, SCSI, IEEE1394 (Firewire) and USB 1.1 / 2.0 drives, PC card storage devices
* Tape drives and tape autoloaders
DOWNLOAD
Boot CD: http://www.fileserve.com/file/jHHgszs/ABRS10 BootCD ISO.rar
ABRS: http://www.fileserve.com/file/hdYqvEd/BuR10.0.13544.part1.rar
http://www.fileserve.com/file/Fhy8uW9/BuR10.0.13544.part2.rar
