Paragon Partition Manager 11 Build 10.0.10.11287 Client/Serv
Gửi bàigửi bởi haychichotoi » 12 Tháng 4 2011, 13:27
Paragon Partition Manager 11 Build 10.0.10.11287 Client/Server (x86/x64) + BootCD
We offer you a versatile set of tools to work with the hard drive that allows you to perform all necessary operations on disk management.
With increasing amounts of hard disk drives increases the importance of optimal allocation of disk space. Multifunctional and easy to use solution for working with disks and partitions Paragon Partition Manager 1911 will help achieve maximum efficiency in the system, as well as improve the performance of your computer at any time when you need it, without reinstalling the operating system and applications.
The composition of Publication
Paragon Partition Manager 1911 version of the kernel 10.0.10.11287
- Client version: x32-64 (Personal and Proffessionalnye) Russian, English + boot image
- Server version: x32-64 only English + program create a boot disk
Addon – Add-ons
- Alignment Tool 2.0.11651 x32-64 Eng. + Program create a boot disk
- Disk Wiper 1910 Personal 10.8101 x32-64 Eng.
- Encrypted Disk 4.0 Eng. x32
Notes
For W7-2008 x64: Despite the fact that the x64 version is put in the folder Program files (x86) it still was imprisoned under x64.
In Russian versions of clients – Help English, read the documentation in Russian attached *. pdf.
See the list of file upload – if you do not need a whole set of software – download selectively (eg BootCd for the client and server to download optional – you can create them from the programs themselves).
Before installing read ReadMeRu.txt in the root folder.
Tested on all XpSp3x32, W7x32-x64, Ws2008R2x64.
http://www.filesonic.com/file/581911641/PPM111001011287.part2.rar
http://www.filesonic.com/file/581909391/PPM111001011287.part1.rar
http://www.filesonic.com/file/581897744/PPM111001011287.part3.rar
