Your Uninstaller! Pro 7.3.2011.02
Công cụ Hệ thống & Tối ưu hệ thống
Gửi bàigửi bởi haychichotoi » 11 Tháng 4 2011, 10:47
| 10 MB
Your Uninstaller! uninstaller software is the industry's leading uninstaller software. It's the world's 1st smart Drag&Uninstall™ uninstaller software under the Windows platform, works on all Windows versions including Windows 7/Vista/XP/2000/ME/98/95/2003. It's as easy as using the recycle bin. Imagine! Just a drag-drop and the program you don't want will disappear from your computer - as well as everything the unwanted program brings! Your Uninstaller! is a user-friendly way of removing unneeded applications on your computer.
It can even remove some annoying spywares! Your Uninstaller! software is a specially designed uninstaller program for both beginning and advanced users. Your Uninstaller! 2008 is extremely very fast and easy to use. It has a unique ability to uninstall items by simply dragging programs' icons into the Your Uninstaller! icon. You may also find the application you want to uninstall through a unique search function.
Key features:
* Completely remove any application installed.
* Deep scan of registry and entire disk for unused registry entries and files.
* Remove programs that could not be removed by Add/Remove Program.
* Uninstall screen savers. [PRO]
* Remove internet surfing traces.
* Backup and restore registry.
* Registration key management.
* Built-in Disk Cleaner helps you find and remove unnecessary files on your disk to save space and make computer faster! [PRO]
* Built-in IE Context Menu Cleaner, cleans the context menu of Internet Explorer. [PRO]
* Built-in Startup Manager, take full control of Window startups. [PRO]
* Fix invalid desktop shortcuts and start menu shortcuts.
* Get the applications detail info even if it hide itself in deep directory, especially useful for finding out "Spy" applications. [PRO]
* Backup/restore installed-applications information.
* Uninstall with SINGLE drag-drop! Just drop a file on Your Uninstaller! icon on the desktop to see what happens! [PRO]
* List installed applications with appropriate icons(same as you see in the Start Menu), you can easily find the application you want to uninstall.
* Powerful search feature allows you quickly find the program you are about to uninstall.
* Automatic detection of invalid installations and removing them with one click.
* Force removal of uninstall related entries in the registry(care to use!). [PRO]
* Lighting speed at startup, 5-10 times faster than Add/Remove Program of Windows XP!
* Export programs list to file or printer.
* More ...
http://www.megaupload.com/?d=KID3KU9U
http://www.fileserve.com/file/BcbhHsH
haychichotoi
Ngày tham gia: 23 Tháng 12 2003, 12:00
Quay về System & Tweak Tools
Đang xem chuyên mục này: Không có thành viên nào trực tuyến.2 khách.
