Turbo Launch v5.1.3
Turbo Launch v5.1.3
Gửi bàigửi bởi Giọt nước » 01 Tháng 4 2011, 07:17
Turbo Launch v5.1.3 HF MU Kelly
Turbo Launch v5.1.3
| 1 MB
TurboLaunch is a fully configurable tool-bar style application that can be set up to run many programs and perform certain pre-programmed actions. Like a toolbar, pictures are used to distinguish what a button is configured to do. TurboLaunch automatically uses the default icon, but you have complete control and can change the icon to whatever you want! The buttons on TurboLaunch are easy to configure! By dragging and dropping programs, files, shortcuts, or folders, you can instantly configure that button to run the dropped object. You can also configure buttons manually by specifying their command, parameters, working folder, and window style. You even have the ability to assign a shortcut key to any button, allowing you to quickly run that button with a simple keyboard command.
» Fully configurable buttons provide single-click access to all of your favorite programs
» The number of rows and columns of buttons can be customized to suit your specific needs
» Buttons can be organized into groups, and they can be resized for greater visibility or to save valuable screen space
» Each button can be configured to run any program, document, shortcut, folder, or drive
» Buttons may be configured to perform certain pre-programmed actions, such as rebooting the system, activating the screen saver, shutting down, and more
» Network connections (such as the Internet or a VPN connection) can be established and disconnected
» A Shortcut Key can be assigned to a button for extremely rapid launching with just a quick keyboard command
» Comprehensive online help and an uninstall option
» Automatic extraction of a program's default icon for use as a picture on the button
» The icon used as the picture on a button is fully configurable: any icon out of any file may be used
» Objects such as programs, documents, shortcuts, folders, or drives may be dropped onto any button to quickly configure TurboLaunch
» Parameters, working folders, window styles, and descriptions are completely configurable
» 16-bit Windows programs may be run in separate memory spaces for greater multitasking efficiency and crash protection
» Dynamic Parameter tokens lets you specify all or part of a parameter at the time you click the button
» "Drop 'n Launch" feature allows you to set up a button so that when a file is dropped on it, the program assigned to that button is started with that file
» Configuration information is stored in the Registry, allowing each Windows user to have their own TurboLaunch configuration
» The configuration can be password-protected to keep unauthorized users from making any changes
» Icon information is automatically cached for rapid starting of TurboLaunch
» "Roll Up When Not Active" option reduces the size of the TurboLaunch window when it is not active
» "Prevent Double Runs" option stops accidental double-clicks on buttons from launching the button twice
http://www.megaupload.com/?d=YBRGSNX0
http://hotfile.com/dl/112661644/764d2b4/TurboLaunch513.rar.html
