Runtime GetDataBack For NTFS v4.21
Công cụ Hệ thống & Tối ưu hệ thống
Gửi bàigửi bởi Giọt nước » 31 Tháng 3 2011, 22:44
GetDataBack will recover your data if the hard drive's partition table, boot record, FAT/MFT or root directory are lost or damaged, data was lost due to a virus attack, the drive was formatted, fdisk has been run, a power failure has caused a system crash, files were lost due to a software failure, files were accidentally deleted. GetDataBack can even recover your data when the drive is no longer recognized by Windows. It can likewise be used even if all directory information - not just the root directory- is missing.
Get everything back, The safe and easy way.
Advanced algorithms make sure that all directories and sub directories are put together as they were, and that long file names are reconstructed correctly. GetDataBack is read-only, meaning the program will never attempt to write to the drive you are about to recover. Our software enables an inexperienced user to conduct their own data recovery by guiding them through three easy to understand steps. If you are an advanced user there are options to adjust the recovery process and improve the results.
Runtime.GetDataBack.For.NTFS.v4.21-DOA.rar
http://turboupload.com/rrt0r28dvu4u
Không có Giọt nước sẽ không có đại dương .... Không có Máy tính làm sao có Mạng ......
Giọt nước
Ngày tham gia: 07 Tháng 6 2003, 11:00
Quay về System & Tweak Tools
Đang xem chuyên mục này: Không có thành viên nào trực tuyến.1 khách.
