PC Fix 2011 v3.02 | 7.3 Mb -=FS=-
Gửi bàigửi bởi Giọt nước » 29 Tháng 3 2011, 22:14
PC Fix Registry Cleaner prevents system slowdowns, freezing or crashing problems, Windows startup issues, partial program removal, obsolete application shortcuts, Java Script Errors, Missing DLL or OCX, Internet Explorer errors, ActiveX Components difficulties, Outlook Express wrongdoings.
Using a high performance Windows registry detection Algorithm and a very simple and intuitive user interface, PC Fix analyzes your entire system registry and repair all PC errors in order to restore your PC optimum efficiency. PC Fix's deep-scanning effectively defragments & compresses your system registry so your PC runs FASTER and smoother than ever before.
The scan results are clearly displayed at the end of each PC scan to enable you to manually select each registry entry for custom repair (of course, you may as well opt for the simple quick automatic repair). Automatic scan and repair process takes from 2 up to 3 minutes on average.
PC Fix automatically creates a backup of your PC registry at each PC scan. You will be able to recover past configurations of your PC registry at any time if required.
Other main features of PC Fix are: Startup Manager, Scan Scheduler, Advanced Repair (that is, customized remote support provided by one of our friendly HELPDESK Support representatives).
PC Fix is provided in many languages to support local communities and users' preferences. Languages include English, Spanish, French, German, Spanish, Italian.
DOWNLOAD
http://www.fileserve.com/file/QXJgPar/PCf113.02.rar
