Windows 8.1 Professional Princess SG 13.10 h86.h64 01.11.201
Windows , Linux ...
Gửi bàigửi bởi Giọt nước » 07 Tháng 11 2013, 23:44
Windows 8.1 Professional Princess SG 13.10 h86.h64 01.11.2013
Windows 8.1 Professional Princess SG 13.10 h86.h64 01.11.2013 | 3.72 GB/2.78 GB
Language : English + Russian LP
The boot disks SG 8.1 Princess 13.10 32-64 bit Language : ENG + Language Pack RUS ( can be set either - installing Win + R, prescribes lpksetup and click OK , then click " Set Language" , the path to the file (included on disc RUS folder "utility" ), then go to Control Panel - All Control Panel Items - Language options - and select the language of the system! Reboot and you - your native language ! Fits any language. )
Requires a driver update.
In order not to burden the operating system drivers ( most of which you do not need ) , decided not to integrate them into the OS
installation:
The downloaded file ( an image in a format iso), write down on a clean , high-quality DVD disk using specialized programs : Alcohol 120 , NERO, UltraISO , etc. , recommended speed when recording from x2 to x8. Format the hard drive on which to install the OS ( this is done in the process)
activation:
In the folder with the images of a promoter KMSpico 9.0.3 - it just work .
System requirements :
CPU: 32- bit (x86) or 64 -bit (x64) processor with a clock speed of 1.8 gigahertz (GHz ) or higher
Memory: 1 GB or more ( GB) ( 32- bit) or 2 GB or more (64- bit) , memory (RAM )
Video Card: DirectX 9 graphics device with WDDM driver version 1.0 or higher
Free space on HDD: 16 gigabytes ( GB) ( 32- bit) or 20 GB (64 -bit system) hard disk space
Checksums of the images :
x86
CRC32: C3D0D762
MD5: C667A54CBEF5BBDEFD33ED440D7F9083
SHA- 1 : 29004062FC286F6E6239B4724E8E664D393B392D
x64
CRC32: 687AB8AC
MD5: C4C1411EF9396B9F74CB7640DD0746D7
SHA- 1 : 414847DED5691F8D60299EAFFCB695BFA8EA213E
Year: 2013
Platform: h86/h64
Medicine:
Size : 3.72 GB/2.78 GB
DOWNLOAD:
http://rapidgator.net/file/ab1c575c85f3adad5166fd2ac8d4fea5/x64Windows_8.1_Professional_Princes.part1.rar.html
http://rapidgator.net/file/4bac3d94312478e68dd06e019f25c88b/x64Windows_8.1_Professional_Princes.part2.rar.html
http://rapidgator.net/file/27692d712ce8fabb6a028c00fcc390ed/x64Windows_8.1_Professional_Princes.part3.rar.html
http://rapidgator.net/file/376f55d9a89a3b220d53a90af5c211c6/x64Windows_8.1_Professional_Princes.part4.rar.html
http://rapidgator.net/file/175ac993b415306ee0ccc44476ebd230/x64Windows_8.1_Professional_Princes.part5.rar.html
http://rapidgator.net/file/0e8696d6d2dcbadfdec4aebad3122383/x64Windows_8.1_Professional_Princes.part6.rar.html
http://rapidgator.net/file/b20968e39e6549da98ab85c23b4515bf/x86Windows_8.1_Professional_Princes.part1.rar.html
http://rapidgator.net/file/bce9eb1c2e1c77becd7fdce86cb8a054/x86Windows_8.1_Professional_Princes.part5.rar.html
http://rapidgator.net/file/ba5741d8107c46fe12c24d43b64234e7/x86Windows_8.1_Professional_Princes.part2.rar.html
http://rapidgator.net/file/167f690e68ef10bc837ab7228e1eb91b/x86Windows_8.1_Professional_Princes.part3.rar.html
http://rapidgator.net/file/f53ef373801f096133ebd79f18407cd8/x86Windows_8.1_Professional_Princes.part4.rar.html
