TeraByte Unlimited Image For Windows 2.82 Retail
Windows , Linux ...
Gửi bàigửi bởi Nửa bốn mùa » 03 Tháng 6 2013, 10:58
Image for Windows is an affordable and reliable drive image backup and restore solution that provides an easy and convenient way to completely backup all your hard drive's data, programs and operating systems. Your
backups can be saved directly to external USB and FireWire™ drives, to internal or network drives, and even directly to CD, DVD, or BD. The Image for Windows package includes an easy-to-use MakeDisk wizard for creating a recovery boot disk. To restore your data, programs and operating systems back to the way they were when the backup was created, simply boot the recovery disk and restore the partition(s) or drive(s) you need to recover. It's that easy.
Image for Windows utilizes the technology provided by Volume Shadow Copy Service (VSS) or PHYLock™, an add-on component included in the Image for Windows package. VSS and PHYLock™ allows you to continue using your computer while the backup is locked to a point-in-time. This eliminates the inconsistencies typically experienced while backing up a partition that is in use.
Image for Windows runs under the Windows operating system, yet it can backup or restore any partition, including those of DOS or Linux, and even partitions encrypted by third-party software.
The TeraByte drive image files produced by Image for Windows are compatible across all TeraByte Unlimited disk imaging products of the same major version number (i.e. all 1.x products are compatible with other 1.x products). This gives you the flexibility to restore disk images using your product of choice.
Image for Windows Features:
Total Reliability - Provides the option to verify each and every byte it backs up.
Convenience - Runs directly from Windows and when used with the free PHYLock™ add-on, it can create a true image of the Windows partition itself, without requiring a reboot.
Security- Your backups can be secured using simple password protection, or full 256-bit AES encryption.
Backup Changed Data- Differential backup option allows you to backup only data that has changed since the last full backup was created.
Simple, Wizard-Driven interface - Easy to use the first time, and every time.
Maximum Compression - By default, compression is applied to the drive images you create.
Maximum Speed - If backup speed is paramount, you can bypass compression entirely.
Optical Drive Support - You can save directly to a CD, DVD, DVD-DL, BD.
Bootable Rescue Discs - Whenever you save directly to a CD, DVD, DVD-DL, BD, it will automatically become a bootable restore disc.
Large drive support - GPT compatible supporting drives larger than 2TiB.
Restore Individual Files or Folders - Using the free TBIView and TBIMount add-ons, you can view the contents of the drive image files, and optionally restore individual files or folders within them.
Compatibility - Automatically recognizes and backs up used area of FAT16, FAT32, NTFS, Ext2, Ext3, Ext4, ReiserFS, and XFS partitions. Partitions with other file system types can be backed up in their entirety. Supports all standard partitions in an MBR, EMBR, or GPT
Windows Servers - Supports both Workstation and Server versions of Windows.
Cost Effectiveness - Includes Image for DOS, Image for Linux, and TBOSDT at no additional charge, making it a uniquely affordable and complete disk imaging solution.
Flexibility - Restore partitions, regardless of the file system on the partition being restored. This gives you the power to restore NTFS partitions from Windows 98 or even DOS (as just a couple of examples).
Wide-Ranging Device Support - Compatible with USB 2 and IEEE 1394 external drives. Better yet, Image for DOS supports these drives directly, without requiring complicated driver installation. (Image for Windows simply uses the drivers already available under Windows.)
Power - Using Image for DOS or Image for Linux (each of which is included with the purchase of Image for Windows) versions gives you the ability to recover your data, even if Windows won't start.
Network Support - Save backups to any drive accessible to Windows itself.
RAID Support - Works seamlessly with on-board hardware- and firmware-based RAID.
Command Line Support - Powerful, complete command line support is built in, allowing you to automate backup or restore procedures.
Scheduling - Leverages the built-in Windows scheduler via the simple click of a Schedule Backup button.
Image File Validation - Allows you to thoroughly check the integrity of the disk image files, either as part of the backup process, or at any time thereafter. TeraByte imaging products are renown for their thorough and accurate validation process.
Restored Partition Expansion - When restoring an image, you can expand the restored partition to occupy any free space that would be left over.
Selectable Image File Sizes - If desired, you can specify a maximum size for the disk image files that are created. This allows you to create image files that readily fit on the removable media of your choice.
Hardware Independent Restore - Restore Windows to completely different hardware and then use the TeraByte OSD Tool Suite to install the drivers required to support the new hardware.
Operating System:
- Compatible with Win64 (x64).
- Compatible with all versions of Windows, including Windows Vista, Windows Servers, W7.
http://turbobit.net/ssnv0eqgu55c.html
http://cloudzer.net/file/o7v8f19l/TeraByte.Unlimited.Image.For.Windows.v2.82.retail-FOSI.rar
http://uploaded.net/file/c1sdg5ci/TeraByte.Unlimited.Image.For.Windows.v2.82.retail-FOSI.rar
http://sanshare.com/vytfubi9olpf/TeraByte.Unlimited.Image.For.Windows.v2.82.retail-FOSI.rar.html
http://rapidgator.net/file/3f6cc70f1b2cad5679f87360985e37a6/TeraByte.Unlimited.Image.For.Windows.v2.82.retail-FOSI.rar.html
Nửa bốn mùa
Ngày tham gia: 06 Tháng 6 2003, 12:00
Quay về Operating Systems - Hệ Điều Hành
Đang xem chuyên mục này: Không có thành viên nào trực tuyến.97 khách.
