VMware Workstation v8.0.2 Build 591240 Final/RePack Lite/Una
Windows , Linux ...
Gửi bàigửi bởi anchang » 02 Tháng 3 2012, 12:00
VMware Workstation v8.0.2 Build 591240 Final/RePack Lite/Unattended EN-RU (2012)
VMware Workstation v8.0.2 Build 591240 Final/RePack Lite/Unattended EN-RU (2012) | 925 MB
VMware Workstation - known program for virtualization. VMware Workstation is a powerful solution for software developers and system administrators who are creating and testing a full-class integrated network applications servers, operating in different environments.
System requirements:
PC Hardware
пїЅ Standard x86-compatible or x86-64-compatible personal computer
пїЅ 1.3GHz or faster CPU minimum
пїЅ Multiprocessor systems are supported.
пїЅ Support for 64-bit guest operating systems is available with Intel VT or AMD-V CPUs.
Memory
пїЅ You need enough memory to run the host operating system, plus the memory required for each guest operating system and for applications on the host and guest. The minimum memory requirement is 1GB, VMware recommends to have 2GB and above. For more information on memory requirements, see your guest operating system and application documentation.
пїЅ As of version 7.0 of Workstation, the total amount of memory you can assign to all virtual machines running on a single host is limited only by the amount of RAM on the host. The maximum amount of memory for each virtual machine is 32GB.
Display
16-bit or 32-bit display adapter is recommended.
Note Use the latest graphics driver recommended for your host.
Recommendations for Windows 7 Aero Graphics Support
To support Windows 7 Aero graphics, VMware recommends the following configuration:
CPU
пїЅ Intel Dual Core, 2.2GHz and above
пїЅ AMD Athlon 4200 + and above
Host GCPU
пїЅ nVidia GeForce 8800GT and above
пїЅ ATI Radeon HD 2600 and above
Memory-at least 3GB of host system memory, 1GB of memory allocated to the guest operating system, and 256MB graphics memory.
Disk Drives
Guest operating systems can reside on physical disk partitions or in virtual disk files.
Hard Disks
пїЅ IDE and SCSI hard drives are supported.
пїЅ VMware recommends at least 1GB free disk space for each guest operating system and the application software used with it. If you use a default setup, the actual disk space needs are approximately the same as those for installing and running the guest operating system and applications on a physical computer.
пїЅ 200MB (Linux) or 1.5GB (Windows) free disk space is required for basic installation. Delete the installer afterwards to reclaim disk space.
Optical CD-ROM/DVD-ROM Drives
пїЅ IDE and SCSI optical drives are supported.
пїЅ CD-ROM and DVD-ROM drives are supported.
пїЅ ISO disk image files are supported.
Floppy Drives
пїЅ Virtual machines can connect to the host's disk drives. Floppy disk image files are also supported.
Local Area Networking
пїЅ You can use any Ethernet controller that the host operating system supports.
пїЅ Non-Ethernet networks are supported by using built-in network address translation (NAT) or using a combination of host-only networking plus routing software on the host operating system.
Language: English + Russian
Medicine: Present
The unique technology of VMware MultipleWorlds isolates operating systems and applications within virtual machines, and the disposal of each virtual machine is a standard PC x86, with its own processor and memory. With this solution you can on a single computer to conduct processes of development, testing, debugging and running multi-tier browser-based applications that exploit the new operating systems and legacy applications on one computer, install new or upgrade existing operating systems without performing partitioning operations drive and restart your computer.
The new platform offers enhanced capabilities for application developers, engineers, quality control, sales of technology solutions and IT-administrators. One of the most notable innovations package VMware Workstation 8 has enhanced support for 32-bit and 64-bit versions of Windows. To display the status of virtual machines are now fully use functions Flip 3D and Aero Peek, implemented in the interface of Windows 7. VMware Workstation Package 8 became the first product with full Aero GUI in Windows 7. Enabling a single application-based technologies DirectX 9.0c Shader Model 3 and OpenGL 2.1, which can be run in virtual machines running Windows.
Key features:
Running multiple guest operating systems on one computer.
Running a virtual machine in windows desktop core operating system and full screen.
Installing virtual machines without re-partitioning.
Starting already installed on your computer operating system without reinstalling or re-configuration.
Running applications on the Windows computer running Linux, and vice versa.
Creating and testing applications simultaneously for different systems.
Starting untested applications without the risk of endangering the stability of the system or lose critical data.
Sharing files and applications to different virtual machines through. use a virtual network.
Running a client-server and Web-based applications on a single PC.
Running on the same PC multiple virtual machines and modeling of the network.
What's New:
Highlights of VMware Workstation 8.0.2 functionality include:
Ubuntu 11.10 is supported as a host.
Fedora 16 is supported as a guest.
Many customer-reported issues have been resolved.
VMware Workstation 8.0.2 is a free update for all VMware Workstation 8 users.
Features RePack Lite & Unattended:
VMware Workstation v8.0.2 Build 591240 Lite for Windows (Russian version) by qazwsxe
Can be installed both in normal and in automatic "silent" mode for silent installation, run with the key / S, for example, like this VMware_Workstation_8.0.2_Lite_Rus.exe / S
The key is case sensitive, and therefore only use the / S, but not / s
It does not require registration.
Unlearn a reboot after install VMware Workstation.
Includes only the Tools-Windows-8.8.2 (for other OS can be downloaded separately).
Interface - Russian (translated by loginvovchyk as amended 1/26/2012).
Deleted folder:
VMware VIX \ *
VMware Workstation \ messages \ *
VMware Workstation \ Visual Studio Integrated Debugger \ *
Removed files:
VMware Workstation \ EULA.jp.rtf
VMware Workstation \ LearnMore.jp.html
VMware Workstation \ TPClntdeu.dll
VMware Workstation \ TPClntjpn.dll
VMware Workstation \ TPViewdeu.dll
VMware Workstation \ TPViewjpn.dll
VMware Workstation \ vmware-remotemks-debug.exe
VMware Workstation \ vmware-vmx-debug.exe
VMware Workstation \ redist \ VMware-Converter-all.exe (instead of the original file - stub)
VMware Workstation \ x64 \ vmware-vmx-debug.exe
Can be installed both in normal and automatic 'quiet' mode.
Does not require registration (S / N is prescribed automatically).
Includes only tools-windows (for other operating systems are located in the "tools").
Integrated on crack loginvovchyk пїЅ http://www.loginvovchyk.ru v18.02.2012 (for VMware_v8.0.2_Lite_Ru).
The size distribution is reduced to 95 MB! by removing the following components:
Deleted folder:
VMware VIX \ *
VMware Workstation \ OVFTool \ *
Removed files:
VMware Workstation \ redist \ VMware-Converter-all.exe (changed stub)
In the folder "tools" are:
tools-linux-8.8.2.exe
tools-freebsd-8.8.2.exe
tools-netware-8.8.2.exe
tools-solaris-8.8.2.exe
tools-windows-8.8.2.exe
tools-winpre2k-8.8.2.exe
Download link:
(Buy premium account for maximum speed and resumming ability)
Bitshare:
http://bitshare.com/files/oxw5l80u/VMware.Workstation.v8.0.2.Build.591240.FinalRePack.LiteUnattended.ENRU.2012.part1.rar.html
http://bitshare.com/files/or859qkw/VMware.Workstation.v8.0.2.Build.591240.FinalRePack.LiteUnattended.ENRU.2012.part2.rar.html
http://bitshare.com/files/vlv5e1z5/VMware.Workstation.v8.0.2.Build.591240.FinalRePack.LiteUnattended.ENRU.2012.part3.rar.html
Uploaded:
http://ul.to/ac7y8bzh/VMware.Workstation.v8.0.2.Build.591240.FinalRePack.LiteUnattended.ENRU.2012.part1.rar
http://ul.to/ntdmkkj5/VMware.Workstation.v8.0.2.Build.591240.FinalRePack.LiteUnattended.ENRU.2012.part2.rar
http://ul.to/9fyoqpgo/VMware.Workstation.v8.0.2.Build.591240.FinalRePack.LiteUnattended.ENRU.2012.part3.rar
Letitbit:
http://letitbit.net/download/80084.84c16ffea974db3a689b8dc3f309/VMware.Workstation.v8.0.2.Build.591240.FinalRePack.LiteUnattended.ENRU.2012.part1.rar.html
http://letitbit.net/download/24008.2cfdb02bb7432e3edcf8b8e30084/VMware.Workstation.v8.0.2.Build.591240.FinalRePack.LiteUnattended.ENRU.2012.part2.rar.html
http://letitbit.net/download/12471.17008db2688b418b35daf31b0e46/VMware.Workstation.v8.0.2.Build.591240.FinalRePack.LiteUnattended.ENRU.2012.part3.rar.html
