Mac OS X Snow Leopard 10.6.4 - Asus (2011)
Windows , Linux ...
Gửi bàigửi bởi anbachang » 14 Tháng 6 2011, 10:12
Mac OS X Snow Leopard 10.6.3 Retail, and then updated using Combo Update 10.6.4 without any problems. The system runs the original (not patched) kernel. The image is intended for installation on the partition MBR.
Of the shortcomings - found that Blue Tooth is living in the system itself, and sometimes falls off. Deal with it but could not.
Installation:
Akronisom create a partition on the hard drive of at least 9 gigs and format in HFS + or HFS.
Copy the image to a flash drive or external drive.
Any convenient way (stick, external drive) and using any distro successfully booted Mac OS (I used the Retail 10.6.3, opened at 8-gigs of flash drive and finished with a tool Netbookinstaller 0.8.4 RC1 http://code.google. com / p / netbook-installer /) load the installer and run Disk Utility.
Connect the USB flash drive with the image in Disk Utility, select the Images -> Scan Image for Restore and set the path to the image to stick. After scanning the image will appear in the left pane of Disk Utility.
Select a previously prepared HFS partition and click Restore.
In the window that opens in the Source field drag our scanned image from the left window in the Destination box, drag the prepared hard disk partition. Daw Erase destination leave it on.
Click Restore to start the process of restoring an image to your hard drive (about 25 minutes).
Reboot and see the window chameleon.
After the first boot I recommend immediately treat the right of access Disk Utility.
If the disc is blank and will be dual-booting, the first to put Windows, then MacOS. The choice of the load will be a chameleon.
System requirements:
Asus Eee PC 1008HA
Intel Atom N280
2 GB RAM
Intel GMA950
Download
http://www.filesonic.com/file/1214320301/MacOSX104_.part01.rar
http://www.filesonic.com/file/1214259841/MacOSX104_.part02.rar
http://www.filesonic.com/file/1214273461/MacOSX104_.part03.rar
http://www.filesonic.com/file/1214253571/MacOSX104_.part04.rar
http://www.filesonic.com/file/1214356391/MacOSX104_.part05.rar
http://www.filesonic.com/file/1214259584/MacOSX104_.part06.rar
http://www.filesonic.com/file/1214313731/MacOSX104_.part07.rar
http://www.filesonic.com/file/1214324321/MacOSX104_.part09.rar
http://www.filesonic.com/file/1214280544/MacOSX104_.part10.rar
http://www.filesonic.com/file/1214280514/MacOSX104_.part11.rar
http://www.filesonic.com/file/1214285554/MacOSX104_.part12.rar
http://www.filesonic.com/file/1214285764/MacOSX104_.part13.rar
http://www.filesonic.com/file/1214280264/MacOSX104_.part14.rar
http://www.filesonic.com/file/1214285624/MacOSX104_.part15.rar
http://www.filesonic.com/file/1214280444/MacOSX104_.part16.rar
http://www.filesonic.com/file/1214285634/MacOSX104_.part17.rar
http://www.filesonic.com/file/1214273934/MacOSX104_.part18.rar
anbachang
Ngày tham gia: 20 Tháng 5 2004, 12:00
Quay về Operating Systems - Hệ Điều Hành
Đang xem chuyên mục này: Không có thành viên nào trực tuyến.17 khách.
