Diễn đàn THIÊN AN • Xem chủ đề - PC Info 3.0.7 Build 7020 (x86/x64)
Gửi bàigửi bởi khongbietlamweb » 28 Tháng 8 2017, 12:06
File size: 53.1 MB
If you really want to call yourself a responsible user, you must first and foremost know everything about your computer, starting from hardware and ending with software.PC Info is a software solution that centralizes all the necessary data belonging to the former category in order to make users aware of their machine’s capabilities as well as how they could exploit it more efficiently.
New PC Info was redesigned and improved to get the best possible experience.
It will quickly scan your PC and get you access to a variety of services and programs.
PC Info has many features:
Quick scan of your PC
Access to a variety of services/programs directly from the program
You can change the theme of the program
You can add the program to the system tray
The program is localized in three languages: English, Русский, Українська
Gets information about all system processes
The application not only gets you precious information about your computer’s hardware configuration but also gives you access to a series of controls you frequently use.
https://cobratek.net/apps/pcinfo/release/app/x64/PCInfo.Setup.x64.exe
https://cobratek.net/apps/pcinfo/release/app/x86/PCInfo.Setup.x86.exe
khongbietlamweb
