Hard Disk Sentinel Pro 4.50.8 Build 6845 Beta
Gửi bàigửi bởi anchang » 23 Tháng 8 2014, 12:43
Hard Disk Sentinel - a utility for monitoring and control of hard disk drives. Allows you to identify potential problems, reduced performance and possible failures. Can warn the user in case of malfunction or excess temperature. Its potential is clearly not seem superfluous, especially in the case of special
value stored data with an increase in the volume of storage. The program monitors the status of hard drives, including indicators of temperature and parameters of the SMART (Self-Monitoring, Analysis and Reporting Technology, a technology built into most modern drives) for each hard drive.
The program monitors the status of hard drives, including indicators of temperature and parameters of the SMART (Self-Monitoring, Analysis and Reporting Technology, a technology built into most modern drives) for each hard drive. Also measures the speed of data transmission in real mode (the indicator can be used for testing or determining the occurrence of low productivity in certain situations). Works in the background and continuously analyzes the situation. In the event of an error threshold or certain parameters specified by the user, a warning. In most cases it comes to the aid of technology SMART, because it is one of the fastest and easiest ways to track changes in critical or critical parameters of the drives.
Hard Disk Sentinel can be used to prevent serious damage or data loss. The program warns the user if a problem before it happens and make it possible to backup important and valuable data. Hard Disk Sentinel runs in the background and constantly analyzes the hard drive. If there is an error or unexpected behavior found, the program warns the user about the current state. Usually, the hard disk may slowly deteriorate from day to day. SMART-technology helps to predict a possible failure by controlling the critical values ??of the disk. The program also displays the current temperature of your hard drive and remembers the previous temperature, which can be used to check the maximum temperature under high boot disk.
- Works with hard drives across the interfaces IDE, Serial ATA and SCSI, determines the status and temperature in real, readings are displayed instantly, no need for long-term diagnosis, shows the current and the minimum temperature storage, the specific attributes depending on the manufacturer, will be useful for advanced users the hour operating time and number of errors read / write performance and interpretation of the value of SMART status percentage for easier understanding;
- With special icons for disks in the system displays the basic values ??of the state and used space, thus simplifies control;
- Can output the current values ??of the temperature in the system tray and follow-up warning in case of exceeding the thresholds, if you wish, you can view detailed information, the status of all hard drives in a window or a small window and a full schedule of temperature change since the start of the program;
- Hard Disk Sentinel defines the model drives and displays detailed information about each of them, starting with the revision number / size of the buffer, and ending it all the other properties; displays current and maximum possible data transfer mode;
- Program keeps track of the total amount of data that have been copied or written to disk, display the current read / write speed and CPU utilization;
- Displays information on all sections of the system, regardless of the number of drives and in the future, these data are used for automatic warning and status display.
http://rapidgator.net/file/2459a1c092599c989106248b6fadad14/hdsentinel_pro_4508.rar.html
http://uploadrocket.net/t3857hi5vyaz/hdsentinel_pro_4508.rar.html
http://uploaded.net/file/c36hy5ph/hdsentinel_pro_4508.rar
http://turbobit.net/8rxjvcu2c2no.html
http://xerver.co/8i72mq7s9c3q/hdsentinel_pro_4508.rar
