MCS Drivers Disk 2013 v10.2.49.798 Revision 130308 (x86-x64)
Gửi bàigửi bởi anbachang » 08 Tháng 4 2013, 15:45
MCS Drivers Disk 2013 v10.2.49.798 Revision 130308 (x86/x64) | 12.5 GB
This CD is a collection of drivers with the ability to install the necessary drivers in a few clicks. The program automatically detects what drivers are needed for the computer. Works with the standard installer, unpacked drivers.
Supported OS:
Windows 2000 SP4
WindowsXP 32/64 bit
Windows2003 32/64 bit
Windows Vista 32/64 bit
Windows 2008 32/64 bit
Windows 2008 R2 64 bit
Windows 7 32/64 bit
Windows 8 32/64 bit
Windows 2012 64 bit (not tested)
Defined devices:
Chipset
Video
Audio
NIC and PCI modems
Controllers HDD
IEEE 1394 Host Controller
USB Host Controllers
CardBus Controllers
USB Devices
LPT printer
Serial external modems
PCMCIA devices
Some common ACPI device.
Number of drivers found by the program for one or Ina OS depends on the availability of those on the disk (limited by disk size) and the correct ways to fill in the appropriate configuration files. Users can add or remove drivers from the disk and supplement the HWID.
This program was written for himself and his friends and, accordingly, comes As Is (as is). Drivers on the disc have not been tested for compatibility with all operating systems for which they are declared. The author is not liable for any damage caused by using the program.
Changes in v10.2.49.798:
[*] Changed the search procedure. (Search only extended databases). Database drivers now are not loaded into memory.
[*] Rewrote the procedure to create the database drivers. (The generator creates now only advanced database and index files)
[-] Restored performance verification program configuration files (v10.1.48.771 always gave out OK.)
[-] If a section of the Manufacturer after the value was a comment, Generator database did not find the section for processing.
[-] Drivers MTD class moved to the directory where the CardBus and should presumably be. Base recreated. (Previously not detected at least JMB38x)
[*] Replaced driver TVAP
[*] Updated some drivers to the current version, and added new ones.
[*] Updated Crystal DiskMark to v3.0.2e
[+] Added Crystal DiskInfo v5.4.1
[*] Updated database devices
[*] Other changes and improvements.
At H & M A N G! This version uses only extended database drivers (* _DBX.ini) + index files (*. Idx) to speed up the search. Is not compatible with versions 9.x and below. For those users who have already created their own database drivers earlier versions 10.0 and 10.1, in the root of the project is a file idxCreator.exe. The utility creates the index files. Enough to run, click the Create button and wait for the completion of work. The files of standard database drivers (* _DB.ini) can be removed.
System requirements: Windows2000 SP4 and above
Buy Premium Account For Faster DownloaD
http://lumfile.com/q3lv9zlxquqm/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part01.rar.html
http://lumfile.com/c0izm4cngc16/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part02.rar.html
http://lumfile.com/55cmjjmnlsag/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part03.rar.html
http://lumfile.com/njmo0zmtt95m/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part04.rar.html
http://lumfile.com/ru22iufoct69/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part05.rar.html
http://lumfile.com/10p06dxl0d1o/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part06.rar.html
http://lumfile.com/2lx27gpu51u7/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part07.rar.html
http://lumfile.com/0ix9myzu31ai/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part08.rar.html
http://lumfile.com/5x65nzytpdde/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part09.rar.html
http://lumfile.com/y2y32kyewwug/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part10.rar.html
http://lumfile.com/09kj9d3zai76/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part11.rar.html
http://lumfile.com/xni36uwx7ily/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part12.rar.html
http://lumfile.com/z3kpalvxj5w3/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part13.rar.html
http://lumfile.com/re7xv7r1v9ka/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part14.rar.html
http://lumfile.com/d5ix3p9rlvz4/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part15.rar.html
oR
http://rapidgator.net/file/daf9f13ac568b49bb4ed1b9e4d0a6368/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part01.rar.html
http://rapidgator.net/file/002ee38782291001ea13ed2cc26995a9/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part02.rar.html
http://rapidgator.net/file/b0b6cf973ff5a513bfb76c4d4f35a260/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part03.rar.html
http://rapidgator.net/file/5cbfdebf21a3b52c80785fc8e2886089/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part04.rar.html
http://rapidgator.net/file/541c2fc7babe213001c553e4d1a078f5/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part05.rar.html
http://rapidgator.net/file/733e0e12a0fcfcad82408a9b668316c4/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part06.rar.html
http://rapidgator.net/file/dbd92b5c6b8b1ed46e65d42e657ffc4b/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part07.rar.html
http://rapidgator.net/file/53f09fb2aed341a4b70972f12d80f465/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part08.rar.html
http://rapidgator.net/file/5660be65cc7482af63887cfd8137ff94/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part09.rar.html
http://rapidgator.net/file/9ab855cdd5e500efc426dfc415fc000d/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part10.rar.html
http://rapidgator.net/file/5dde37b9f0904f883ee2648616a45ceb/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part11.rar.html
http://rapidgator.net/file/1fb62dd200922e6402c52057fe2b1711/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part12.rar.html
http://rapidgator.net/file/4c60d6ac1d76b4c5771cedf9cf8b5a3f/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part13.rar.html
http://rapidgator.net/file/9ffd62f84b1df82345e5570d7a795711/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part14.rar.html
http://rapidgator.net/file/466a70959a93b5cefee70ee0bb6d9981/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part15.rar.html
or
http://ryushare.com/4364c02fad44/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part01.rar
http://ryushare.com/419316exf1b/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part02.rar
http://ryushare.com/444d94dca664/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part03.rar
http://ryushare.com/427beb8vb635/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part04.rar
http://ryushare.com/4364c02b9249/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part05.rar
http://ryushare.com/444d94dna67b/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part06.rar
http://ryushare.com/419316en9f29/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part07.rar
http://ryushare.com/444d94d4a67c/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part08.rar
http://ryushare.com/419316em9f2a/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part09.rar
http://ryushare.com/444d9wca67d/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part10.rar
http://ryushare.com/419316a9f2b/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part11.rar
http://ryushare.com/4364c0af925e/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part12.rar
http://ryushare.com/4364c02f925b/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part13.rar
http://ryushare.com/4193a6e59f30/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part14.rar
http://ryushare.com/4364c02f925c/MCS.Drivers.Disk.v10.2.49.798.Revision.130308.part15.rar
