SSDlife Pro v2.2.39
SSDlife Pro v2.2.39
Gửi bàigửi bởi anchang » 14 Tháng 12 2011, 16:35
SSDlife Pro v2.2.39
SSD Life analyzes how actively you use your solid-state drive and uses a special algorithm to calculate its estimated lifetime. Of course, the date of the lifetime expiration is corrected depending on how intensively you keep using your drive.
The entire information about your SSD — from general (manufacturer, model) to technical (whether your drive/system supports TRIM) — is displayed in the main window of SSD Life. Sometimes you may need it to find out how many hours the drive has already been in operation, for example, when you buy a used SSD.
SSDlife.Pro.v2.2.39.RETAIL-TE.rar
http://upload-pro.com/hdxz5fmb9alh/SSDlife.Pro.v2.2.39.RETAIL-TE.rar.html
