Uniblue Driver Scanner 2010
Máy vi tính của tôi nó gồm những gì ?
Linh kiện nào tốt , xấu ....
Đặc tính kỹ thuật của thiết bị ?
sửa chữa phần cứng ???
Hãy cùng nhau đàm luận
Gửi bàigửi bởi Giọt nước » 28 Tháng 8 2010, 13:01
Uniblue Driver Scanner 2010 | 5Mb
Computers run hardware devices, such as printers or graphics cards, using software called drivers. Without drivers you wouldn’t be able to print a document, read this webpage or connect to the Internet. All hardware elements in your PC, including your graphics and sound card, your motherboard, your hard disk, your modem or even your keyboard, come with drivers. Initially these may have come preinstalled with the operating system, or you may have installed them from the manufacturer’s CD. However the manufacturers will since have improved these drivers by removing bugs and adding extra features or functionality. This means that unless you update your drivers regularly you may face any of a range of problems, from the relatively minor, such as hardware that seems buggy and poorly performing, to the more major such as hardware failures, conflicts and complete system crashes.
The Solution:
With so many drivers installed on your system you cannot reasonably keep track of which drivers have been updated, which is why you need driver update management software to help out. Driver Scanner is the perfect solution for automatically updating drivers, saving you the hassle of having to identifying all your system’s drivers, then find updates for them using, before then downloading them from the manufacturer’s website. Driver Scanner scans your PC’s drivers and checks them against our comprehensive library of the latest drivers, to give you a full list of all those that need to be updated. With single click simplicity Driver Scanner will then install each update on your PC. But what’s more, Driver Scanner will also backup all your drivers to an external device, meaning that the next time you reinstall your system you can load up all your latest drivers, from one place.
- Faster installation (smaller application)
- Faster drivers scan
- Better overall scan engine improvement
- Minor Bug fix
Không có Giọt nước sẽ không có đại dương .... Không có Máy tính làm sao có Mạng ......
Giọt nước
Ngày tham gia: 07 Tháng 6 2003, 11:00
Đang xem chuyên mục này: Không có thành viên nào trực tuyến.4 khách.
