Kaspersky WindowsUnlocker Multilanguage (17.06.2011)
Gửi bàigửi bởi anbachang » 22 Tháng 6 2011, 20:39
If you are working with a computer screen has a banner (advertising unit) with the requirement to send SMS to the number specified in the message, it means that you are a victim of extortion-blocker. The purpose of the programs of action for extortion is to block user access to data or limitation of opportunities to work on the computer and demand a ransom for the return to the original state of the system.
In order to combat software-extortionists Kaspersky Lab experts have developed a special tool Kaspersky WindowsUnlocker. The utility is run when the computer with Kaspersky Rescue Disk 10 and allows you to work as a graphic mode download Kaspersky Rescue Disk, and in the text.
Kaspersky WindowsUnlocker utility allows to treat registry of all operating systems installed on your computer (including installed at different sections in different locations of one partition), and treatment of user registry branches. Kaspersky WindowsUnlocker does not perform any file operation (for the treatment of infected files, you can use the Kaspersky Rescue Disk 10).
Boot the computer with a disk containing Kaspersky WindowsUnlocker:
1. Download the disk image utility Kaspersky WindowsUnlocker.
2. Burn the image to the desired carrier.
2.1 Recording an image utility CD / DVD-ROM.
You can burn the iso-image to a blank CD / DVD using any program for recording optical disks (eg, Nero Burning ROM, ISO Recorder, DeepBurner, Roxio Creator or other program).
3. Run the file rescue2usb.exe and follow the onscreen instructions.
After that, you need to boot from a mounted diska.V result, download the Linux operating system with the definition of the devices connected to a computer, and finds the file systems on hard drives and external. After loading the operating system, you can get to work.
If the operating system loaded computer is in sleep mode, or work with it has been completed correctly, the program will notify you.
In order to properly shut down the operating system, in box, click Restart.
If you press the Continue button, Kaspersky Rescue Disk 10 will continue to mount the file system, but it may damage it.
If you click the Ignore button, Kaspersky Rescue Disk 10 misses mount the file system. In this case, you will be able to scan the boot sector and startup items. In this file system can also be damaged.
4. The utility and Treatment Registry
For the treatment of the registry using Kaspersky WindowsUnlocker follow these steps:
If you downloaded the Kaspersky Rescue Disk in graphical mode, press the Start button in the lower left corner of the screen and then click Kaspersky WindowsUnlocker.
If you downloaded the Kaspersky Rescue Disk in text mode, the user menu using the arrow keys up / down to select the Kaspersky WindowsUnlocker and press the Enter key on your keyboard.
The utility will automatically launch and guide treatment of the registry. The result of the utility appears in the root.
http://www.filesonic.com/file/1269571364/KRD_Unlocker.rar
