WaterProof PHPEdit 5.0.0.12872
Gửi bàigửi bởi anchang » 14 Tháng 8 2013, 14:42
PHPEdit is an Integrated Development Environment (IDE) for PHP designed for professional. Including advanced php related tools, powerful debugger and profiler, code beautifier, help integration, real time syntax checker, advanced keyboard templates and much more.
By using PHPEdit you will:
1. Develop Faster
Because PHPEdit contains several tools to increase your personal productivity like Syntax Highlighting, Code Hint, Code Insight, automatic Code Completion, Keyboard Templates, Quick Marks, Code Browser...
2. Enhance Quality
Using the debugger you will produce better software because you'll be able to put breakpoints, step inside your code, watch variable content, check call stack and more. Using the profiler, you will tweak your application performances.
3. Make Your Life Easier
Because PHPEdit is fully customizable you can make it behave the way you want. You will not change the way you work, but you'll work faster and easier because all your tools are just a shortcut away.
http://sanshare.com/ix947sujejlt/WaterProof.PHPEdit.v5.0.0.12872REDT.rar.html
http://akafile.com/52xtx15r3ea9
http://rapidgator.net/file/55347c6c541d018ef6645b9e1829aac4/WaterProof.PHPEdit.v5.0.0.12872REDT.rar.html
http://cloudzer.net/file/n5wm8hrt/WaterProof.PHPEdit.v5.0.0.12872REDT.rar
http://turbobit.net/jkkqp7jsnb4f.html
