Sothink JavaScript Web Scroller 2.3.223
Gửi bàigửi bởi Giọt nước » 17 Tháng 6 2013, 09:11
Thanks to Sothink javascript Web Scroller you will be able to create functional and attractive web scrollers. Your web sites can benefit from a scroller because Scrolling content attracts visitor's attention and saves space for web page. With this program, you can create scrollers for ads, events, news, slide shows, and many other purposes in minutes, with NO javascript experience required.
The generated Scroller is compatible with most major browsers and it can detect the browser's window size automatically to adjust its size. All the images are pre-loaded so it will reduce the download time. There can be multiple scrollers on a page and the same scroller on multiple pages. There're no limits on number of items included in a scroller and items can include images, text, their combination or HTML code. Items can include popup tips and links, with wrapping text supported. HTML code can be used in item text, title text and popup tip.
The appearance of your scroller is completely configurable - Rich built-in templates and image library help you create a new one. Title, pagination, popup tips and scroll arrows are four optional parts, which you can choose freely. You can click the arrow button or choose auto scroll option to control scrolling and scrolling speed is adjustable. Fully customizable properties, including images, text, font, backgrounds, colors, links, alignment, spacing, padding, etc make your scroller attractive.
User-friendly interface of the program helps you modify your scroller easily and preview its effect in real time. You can add, delete, select items and adjust their order easily in the List panel. You can edit multiple items at one time or Copy & paste between items. Exclusive Publish helps to add your scroller to web pages in a fast and easy way. Web Path for resources files and Link Prefix enable you to switch your project locally and on the web for testing purposes. Sothink javascript Web Scroller supports any doctypes, and supports UTF-8.
Here are some key features of "Sothink javascript Web Scroller":
· Cross browser compatibility (Immediate coverage of browser updates)
· User-friendly interface with live preview
· Creates scroller including pure text , images or a combination of both of them, with no limitations on the number of images
· All the images are pre-loaded
· Drag and drop thumbnails in the List panel to adjust the order of items quickly
· Choose auto scroll option or click the arrow button to spring scrolling
· Scrollers created by the program will automatically detect the browser's window size and automatically adjust the size
· Click here to view the example>>
· When mouse moves over images, a popup tip will be shown with an animation effect
· Built-in templates give you better choices
· Exclusive Publish helps to add your scroller to web pages in a fast and easy way
· Title, pagination, popup tips and scroll arrows are four optional parts, which you can choose freely as you like
· Fully customizable properties, including images, text, font, backgrounds, colors, links, alignment, spacing, padding, etc
· Image Library and Image Border provide rich resources
· Any HTML code can be used in item text, title text and popup tips
· Wrapping text is supported in item's setting
· Supplies multiple scrollers on the same page and one scroller on multiple-pages
· Scrolling repeats if scroll is at "end" in either direction with the option "Loop Scroll" checked
· Web Path for resources files and Link Prefix enable you to switch your project locally and on the web for testing purposes
· Edit multiple items at one time
· Copy & paste functions
· Supports any doctypes, and supports UTF-8
http://turbobit.net/2aols44p445v.html
http://rapidgator.net/file/74f0ebe7309d892b2b9c80d04d34d24f/Sothink.JavaScript.Web.Scroller.v2.3.223.Incl.Patch.InternalMeGaHeRTZ.rar.html
http://uploaded.net/file/8w06kuv5/Sothink.JavaScript.Web.Scroller.v2.3.223.Incl.Patch.InternalMeGaHeRTZ.rar
http://cloudzer.net/file/nuimx6k3/Sothink.JavaScript.Web.Scroller.v2.3.223.Incl.Patch.InternalMeGaHeRTZ.rar
