phpDesigner 7.2.5.10
Gửi bàigửi bởi khongbietlamweb » 10 Tháng 5 2011, 22:08
phpDesigner is more than just a powerful and lightning fast PHP IDE and PHP editor, it is also a full-featured HTML, CSS and JavaScript editor and even more! -- for both beginners and professional developers!
phpDesigner assists you with editing, analyzing, debugging and publishing applications and websites powered by PHP, HTML and many other web languages!
Key Features:
* Lighting fast and easy to learn and use! View screenshot!
* Full-blown PHP, HTML, CSS and JavaScript editor View screenshot!
* Intuitive, customizable workspace with theme support View screenshot!
* Syntax highlighting for PHP, HTML, CSS, JS etc. View screenshot!
* Code explorer View screenshot!, code completion View screenshot! and code tip
* Project manager and project workspace
* Find declarations in projects in an intuitive way View screenshot!
* Debug and profile PHP code with Xdebug View screenshot!
* Live error detection for PHP, HTML and CSS View screenshot!
* Remote ftp editing View screenshot!
* Advanced search and replace View screenshot!
* Code snippets library and templates
* TortoiseSVN support
* Fast code beautifier for PHP, HTML and CSS
* Show matching and missing brackets and tags View screenshot!
* Learn PHP with integration of the PHP manual
Boost your Productivity
Boost your productivity and simplify complex coding projects with tons of features to speed up your development!
PHP, HTML, CSS, JavaScript and a lot more!
phpDesigner is not just a powerful PHP IDE and editor but also a HTML, XHTML, MySQL, XML, CSS, JavaScript, Smarty, VBScript, Java, C#, Perl, Python and Ruby editor!
Intelligent Syntax Highlighting
Switch automatic between syntax highlighters for PHP, HTML, CSS, and JavaScript dependant on your position in the file while dimming the rest of the code so you can better keep focus! - ideal for Ajax developers!
Object Oriented Programming with PHP
Work with object-oriented programming in PHP with nested code completion support and advanced code tip as you type!
Debug and Profile with Xdebug
Analyze your code step by step using breakpoints, watches and evaluations. Find bottlenecks or see which parts of your code are slow and could use a speed boost with the profiler!
Learn PHP
The integration of the PHP manual allows you to learn and explorer the world of PHP. Shorten your learning curve!
Easy to Learn. Enjoyable to use for hours!
The philosophy behind phpDesigner is to make it, enjoyable to use for hours for both beginners and professional developers through an easy-to-use-, intuitive-, customizable- and tabbed interface and workspace!
http://www.filesonic.com/file/954060514/phpDesigner.7.2.5.10.patch-UST.rar
khongbietlamweb
Đang xem chuyên mục này: Không có thành viên nào trực tuyến.12 khách.
