Xilisoft Photo to Flash 1.0.1.0224 | 29 MB -=HF=-
Gửi bàigửi bởi anchang » 19 Tháng 3 2011, 22:28
Xilisoft Photo to Flash is the best flash slideshow maker which can create dynamic flash slideshows from a dozen of photos in formats of jpg, jpeg, png, gif, bmp, tiff, xbm, xpm to SWF, XML and HTML output formats.
To create personalized flash, you are enabled to add background audio, make a choice from many given flash templates, adjust the orientation and display sequence of the imported photos and etc. With Xilisoft Photo to Flash, your photo collections can be turned to a dynamic and vivid flash show.
* Create great flash from a dozen of images in formats of jpg, jpeg, png, gif, bmp, tiff, xbm and xpm
* Export images to SWF format flash, HTML codes and XML files
* Apply your favorite audio as the background sound of created flash
* Multiple flash templates are free to choose to simplify the creation of flash
* Customize the orientation and display sequence of the imported images
* Background audio editing functions are offered
Create Flash from Multiple Image Formats
Create flash from multiple image formats, including jpg, jpeg, png, gif, bmp, tiff, xbm and xpm.
Support Adding Various Audios as Background
Xilisoft Photo to Flash enables you to add background sound from various audio formats, like aac, aif, aiff, ac3, ape, au, flac, mpa, mp2, mp3, ogg, ra, wav, wma, m4a to enrich the output effect of flash.
Multiple Templates are Given
Multiple templates are given to simplify the design of flash, 3D templates are provided as well.
Edit on Imported Images
Adjust the orientation of the imported photo collections; fine-tune the display sequence of images by drag-and-drop.
Personalize the Background Sound
Personalize the background sound by setting the play order of background audio, clip background audio to retain the favorite segment, add fade-in and fade-out effects, you can also set the loop mode to play background sound automatically.
Export Images to SWF or HTML Files
Generate SWF file or publish as HTML flash gallery directly.
Support XML Output Format
support XML as output format and enable you to update images in the flash gallery without the program.
Multilingual Interface
English, German, Spanish, French, Italian, Japanese, Simplified and Traditional Chinese interface languages are optional.
DOWNLOAD
http://www.fileserve.com/file/zvWyD2p/XP2F1.0.1.0224.rar
