VB.Net to C Sharp Converter 3.06
VB , C++ , JAVA , .... ,
Thuật toán ....
Gửi bàigửi bởi Giọt nước » 14 Tháng 10 2013, 15:07
Are you ready to convert your VB.Net code to C#? All versions of Visual Basic.Net are supported: 2003, 2005, 2008, and 2010 as well as all project types (Win Forms, Web, Class Library, Compact Framework, Silverlight, etc.).
Key Features:
* Support for the latest Visual Studio features - The latest VB.Net / C# features are supported, including LINQ, XML, WPF, Lambda expressions, and extension methods.
* Support for All Project Types - Win Forms, Web, Class Library, Compact Framework, Console, etc.
* High Accuracy - This release was stress tested on thousands of sample programs. Tested were hundreds of Microsoft sample projects (101 VB.Net samples, DirectX samples, etc.), in house and customer projects, third party control samples (Infragistics, ComponentOne, Telerik, etc.), and open source projects from SourceForge.
* Ease of Use - While the conversion logic itself is complex, using the converter isn't. You are guided through each step of the process with easy, clear instructions.
* Customization - Not every project is the same. With dozens of conversion options to choose from, you are in control of the conversion process.
* Convert Single Projects or Groups of Projects - You can create lists of programs and convert them with one click. There's also a command line version included.
* Comprehensive Reporting - There are reports showing potential trouble spots in your code, interesting things which happened during the conversion process, and any C# compiler errors which need to be fixed.
http://rapidgator.net/file/d18a3ab22677a4b74d6934680faa8ad6/VBConversions.VB.Net.to.C.Sharp.Converter.v3.06.rar.html
http://turbobit.net/izxubzgikr28.html
http://akafile.com/usaruresen2n
http://uploaded.net/file/n6cq7c69/VBConversions.VB.Net.to.C.Sharp.Converter.v3.06.rar
http://cloudzer.net/file/6a0gsvjy/VBConversions.VB.Net.to.C.Sharp.Converter.v3.06.rar
Quay về LẬP TRÌNH Ứng Dụng
